Mikey's right. I believe webbing in the first four bays from center is usually adequate.
This is the time to check the wing for minor twist, because if there is any, you might lock it in place with the webs. To check for twist, get a couple of CF tubes or arrow shafts, I've even used yard sticks on edge. Lay them so they sit resting on the spar and TE as close to the tips as possible(make sure your reference sticks are not laying in a dent or a dip in the TE or spar). Back off 15' and crouch and eyeball the two sticks and see if the farther one disappears behind the closer one. If there is any twist in the wing, the sticks will be criss-crossed, so it will be apparent. Careful work with ammonia glass cleaner, heat and force can be used to straighten it. You probably will have to counter twist it slightly to get it straight when released after it dries. A hot hair dryer helps, but not a heat gun.
This is just my method, others may disagree, so proceed thoughtfully.
Rusty
P.S. I realized after writing that, Mike said block it up straight... same thing I'm getting at, but this will help it be straight when you do block it in place.
