  • July 12, 2025, 10:44:25 PM
Author Topic: Not to sure about these air filters..... what is your experence with them?  (Read 1751 times)
So as I removed hardware from the TwistStang I got a good look at the air filter. I then removed it from the rubber case and saw this.
As it has been coming apart wonder where it has all gone?
Guess I need to change them more often???
Offline Charlie Pate
Re: Not to sure about these air filters..... what is your experence with them?
« Reply #1 on: February 03, 2009, 01:46:41 PM »
The Only thing they are good for (mainly) is to make your engine ,no matter what brand, last longer;much longer.
This is NOT an opinion(theory) but a proven fact. If your disagree, just remove the one from your car and
drive it in dusty conditions for a short while.
Let me put it this way; Randy Smith and Richard Oliver both reccommend them highly.NASCAR   cup cars   use air filters.
Personally, I only run them on engines I wish to keep.
While they may rob you of a small bit of power (which can be overcome) the pluses far outweigh the minuses.
 The one you have shown appears to be a Bru Line coarse mesh; the fine mesh ones are green.
 Yours appears to be a little like Jimmy Lynch "OLD".
 The oil and fuel eventually cause the mesh to deteriorate. I have seen them get so bad in power mowers that
 the entire element has been sucked into the engine and ground up.
 So, yes they need to be replaced at the first sign of deterioration . I believe once a season would get you thru
 easily , maybe longer. y1
« Reply #2 on: February 03, 2009, 02:09:14 PM »
I'm kinda going with the panty hose and "O" ring option, myself. But I have used Bruline filters in the past.
« Reply #3 on: February 03, 2009, 03:47:17 PM »
When the weather cleared up last spring I started noticing one of my engines was significantly down on power.  Eventually I pulled the filter and suddenly all the power was back.  Shortly after I noticed that castor had set up on the bottom side of the filter and was choking the intake.  A new element cleared it up and the power was back to normal.  They're like everything else, they should be checked on a regular basis.
Offline Jim Treace
  • 1979 600 Aerostar N79JT
« Reply #4 on: February 03, 2009, 05:26:57 PM »
I like the "O" ring and panty hose, too. Easy to apply, can be doubled to restrict air flow, if necessary and actually act as a bit of protector if you engine happens to meet the dirt (the Bruline would do this too).
No dirt got into my intake.
Jim
ps: this is the last picture of my crashed Tutor II I will show!
Jim Treace
Ponte Vedra Beach, FL &
Paris, TN
AMA 855251 "Too soon we grow old...Too late we grow wise"
« Reply #5 on: February 03, 2009, 06:56:39 PM »
Hey Jim,
Maybe after you get the mud off you can show me how you make that filter?
Offline Jim Treace
« Reply #6 on: February 03, 2009, 07:06:31 PM »
Hey Paul,
I'll do better than that, I'll give it to you! The mud is free!
Jim
Jim Treace
Paris, TN
« Reply #7 on: February 04, 2009, 12:44:13 AM »
   Well, that's pretty dirty. I would clean mine in either SIG Airplane Cleaner (the stinky solvent kind, not the water-based product) or IPA about once a year. Put it in an old 35 mm film can, pour in about 1/4" of cleaning fluid, and shake the heck out of it. That will get it clean.
   I used those pretty religiously for quite a while. The only time I ever had a problem was (predictably) at the 1997 NATs. The element broke away from the plastic ring for about half the circumference, on a qualifying flight, and the engine went slightly lean. Fortunately it was near the peak anyway, so it had only a minor effect.
     The only issue is fitting in the cowl. When I went to the RO-Jett, the "trumpet" intake didn't give me enough clearance, so I switched to the panty-hose and o-ring. It probably doesn't filter as well, but it takes up almost no space. Either style does a  decent job of acting like a diffuser, or so it would seem.
    You can use any of these to make slight venturi tweaks. The "coarse" gray filter, or about two layers of pantyhose, is about like subtracting about  a half AWG # drill size, and the "fine" tan/amber filter like you show, or about 4 layers of pantyhose, is about a full AWG # drill size.
    I use the Bru-line filter on the Skyray, as it keeps the dirt from the inevitable crashes out of the engine. It works well for that even without the element - the rubber part bends over the intake when it enters the ground and covers it up. Other than that I would be surprised if it did much unless you are taking off in a very gritty/dusty area.
Online Howard Rush
« Reply #8 on: February 04, 2009, 10:30:26 PM »
Pantyhose is bad enough.  I don't want to think about what you guys do with the O ring.
« Reply #9 on: February 05, 2009, 10:10:49 AM »
Same as you, Howard, but we have to use bigger ones.  ;D
« Reply #10 on: February 05, 2009, 07:23:43 PM »
LMAO  LL~
