  • June 29, 2025, 05:50:27 PM
Author Topic: Not Model Aviation but a REALLY scary surprise!  (Read 2720 times)
Offline Robert Zambelli
« on: December 01, 2016, 08:09:50 AM »
The exhaust system on my Cessna 120 requires inspection every 25 hours, according to a placard on the dashboard.
I inspect it every 15 hours.
This last time, I did the inspection after 13 hours and got quite a shock!  ~^  ~^
The port side muffler was blown out as seen in the picture. When I inspected it 13 hours ago, there was not a single hole or crack. If fact, I tap it with a screwdriver handle to check for soft spots.
This is the side that is attached to cabin heat, which fortunately I have not used recently.
Offline Russell Shaffer
Re: Not Model Aviation but a REALLY scary surprise!
« Reply #1 on: December 01, 2016, 08:14:49 AM »
Fortunate catch.  Time to buy one of those muffler patch kits from Walmart?
Russell Shaffer
Klamath Falls, Oregon
Online Motorman
« Reply #2 on: December 01, 2016, 10:14:16 AM »
Don't you have a monoxide detector in the cockpit?
Offline Mike Scholtes
« Reply #3 on: December 01, 2016, 01:40:53 PM »
Wow, that IS scary. Is there a modern stainless replacement maybe? I had a similar but not nearly as bad situation with the muffler on the A65 in my T-Craft, requiring frequent inspection and some repairs. This seems like something there should be (or maybe is) an AD on, in addition to placarded warnings.
  • Gravitywell
« Reply #4 on: December 01, 2016, 02:37:54 PM »
Shows you just how hot those babies run!  Good catch.
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline peabody
« Reply #5 on: December 01, 2016, 04:34:03 PM »
Hey Z-man....
A friend from NJ was prototyping a stainless 4 into 1 on his Cessna....allegedly a power increase and a weight reduction....it sounded pretty cool, too. Any progress in that area?
« Reply #6 on: December 06, 2016, 01:18:35 PM »
Yes, I have carbon monoxide detectors in both of my aircraft.
Since the cabin heat has not been on in a long time and the fresh air vents were open, I never got an indication.
When the cabin heat in the Cessna is closed, it seals very tight and nothing comes in the cabin.
« Reply #7 on: December 06, 2016, 04:51:18 PM »
thats the heat box tho / , not a muffler . Is It . So youd loose the warm air in - out through the ole .  :-\
« Reply #8 on: December 06, 2016, 04:56:51 PM »
Hi, Matt.
No, that is the muffler. I removed the heat boxes to do the inspection.
That's when I found the deteriorated mufflers - inside the heat boxes.
Offline Skip Chernoff
« Reply #9 on: December 06, 2016, 06:48:19 PM »
Count your blessing,that could have been ugly. Great catch........PhillySkip
All better now!
« Reply #10 on: December 18, 2016, 05:13:02 AM »
Just finished installing the new system.
Upgraded by STC, fits perfectly.
Offline Chuck_Smith
« Reply #11 on: December 18, 2016, 06:11:27 AM »
Looks nice! And what's baby blue in the background? Is that Daphne blue?
AMA 76478
« Reply #12 on: December 18, 2016, 07:10:28 AM »
That's my baby blue 1974 FIAT Spider - one of the most reliable and fun to drive cars I've ever owned! I've had it since 1976.
Offline Mike Lauerman
« Reply #13 on: December 18, 2016, 05:35:31 PM »
'Z' man is very 'car-anointed'.
Glad you found that 'heat annoyance' in time, Robert!
« Reply #14 on: December 18, 2016, 08:42:06 PM »
Me too, Bob, I'm sure glad you do such timely inspections. Was it the original muffler, or is that a part that needs periodic replacement?
Damn glad you're still with us.
Rusty
« Reply #15 on: December 18, 2016, 09:41:41 PM »
Those new mufflers look more better, Bob!
Chris...
« Reply #16 on: December 21, 2016, 07:23:46 PM »
Rusty
Hi, Rusty - yes, as far as I know, the mufflers were original, from 1946. I could not find anything in the log books alluding to replacement.
The one in the photo was on the port side of the plane.
When I removed/inspected the one on the starboard side, I found several places where it had been welded - more than likely to repair cracks.
Anyhow, the new mufflers will outlast me!
