  • July 01, 2025, 08:57:44 AM
Author Topic: Legacy Build  (Read 90377 times)
Re: Legacy Build
« Reply #350 on: March 31, 2024, 04:58:45 PM »
Oh, right - hardware.
Offline Paul Walker
Re: Legacy Build
« Reply #351 on: March 31, 2024, 05:51:48 PM »
And I thought stressmen were conservatine. You take it to another level.
 ;D
Re: Legacy Build
« Reply #352 on: April 06, 2024, 12:58:35 PM »
Horn done.  It doesn't fit in the fuselage -- oh my.
Re: Legacy Build
« Reply #353 on: May 08, 2024, 07:26:03 PM »
Elevator rod, with hex key flap tweaking.
Re: Legacy Build
« Reply #354 on: June 02, 2024, 02:23:44 PM »
Wing glued in, waiting on the glue to dry.  First step was to measure it every which way, to make sure the incidence of the wing matched the level reference of the top of the fuselage and was square to the fuselage.  Second step was to block it all in place.  Third step was to gain courage.  Then I mixed up some glue, got it dotted onto the wing & fuse in a number of spots to hold everything in place, measured everything several more times while the glue was still soft -- then I left the room & cut some ribs for an OT plane.
Re: Legacy Build
« Reply #355 on: June 16, 2024, 05:36:11 PM »
So I measured once, measured twice, measured again, glued, measured again, and everything was looking good.
Then I noticed that I had messed up my reference marks on the wing -- the outboard was 25 3/8" away from the fuselage side, the inboard was 25 3/4" away from the fuselage side.  Worse, I was running on a headache that day, so it was lost on me that the distance from the inboard side to the tail post was 34 1/8", while the distance to the tail post was 33 7/8" (think of that as "one eight inch different from 34 inches" and you may see my mistake).
I only noticed it after the headache because my wife noticed the wing wasn't square -- I remeasured it to show her it was too right -- and damned if it wasn't wrong!
So -- everything has been ripped out, measured correctly (I hope) and re-glued.  I had to beat up the stab a bit to get it out, but better than a crooked stab -- and it straightened up nicely with a bit of water insinuated under the covering and ironed with a Monocoat iron.
I've got the guide tube for the flap tweak mechanism in place, and all the bottom sheeting on.
Now I just need to get the hatch details figured out.  It'll run from nose to behind the cockpit, per a picture I saw of -- I think -- one of Denis Nunes' planes.  Mounting details involve -- uh, plywood and screws and pegs and stuff -- yes, that's it, all that.  Real mounting details are to be determined, but it'll be cool when it's done, yes it will!
Re: Legacy Build
« Reply #356 on: June 29, 2025, 07:24:53 PM »
A couple of weeks before he passed away, Dave Royer told me that in all the time I've been chasing a 20 point finish on this plane I could have been contesting a 10-point plane and getting a hell of a lot more appearance points than zero.
I wish Dave were alive to see me fly it, even if it is an aesthetic horror.
Technically I could fly this thing just as it sits in this picture.  All I need to do is scare up a set of lines.
It has a RC receiver in it, though, and I need to set up the timer and the ESC.  So I'm going to do that as well as find lines, and see if maybe I can have it in the air soon.
Now I just need to decide between a 12" two-blade or a 10" three-blade, and if I go with the 3-blade, find a spinner.  Because a spinner should be worth some apperance points - right?
