  • July 19, 2025, 05:47:45 AM
Author Topic: Not C/L but thought some might be interested.  (Read 1148 times)
Offline Phil Coopy
« on: February 07, 2010, 08:16:09 PM »
As  side project I am in the process of building a 1/3 scale SE 5 (Eberhardt version).  The SE 5 was one of the earliest planes to use a hinged stabalizer for pitch trimming. So in an effort to play to the judges, I came up with the mechanism pictured below.
Phil
Offline John Witt
Re: Not C/L but thought some might be interested.
« Reply #1 on: February 07, 2010, 08:18:59 PM »
Neat looking mechanism, Phil. What's the total movement of the stab LE?
John W
John Witt
AMA 19892
Edmonds, WA
"Houston, Tranquillity Base here. The Eagle has landed."
Offline Phil Coopy
« Reply #2 on: February 07, 2010, 09:11:25 PM »
John,
I made it the same as the full scale.  +5 to -2 degrees.  Got it from a set of original rigging instructions.  However on the full scale SE5, the stab LE is fixed and the TE moves up and down via a jack screw linked by cable to a hand wheel next to the pilots seat.  That's why I put the actuator on the rear stab spar and hinged the forward spar.
Phil
« Reply #3 on: February 07, 2010, 09:21:13 PM »
My own version of the Fokker EIII was R/C.  In an effort to be more scale-like, the empennage was all-flying, and the wing panels pivoted, from steel bars and tube.  It was published in a magazine (the one newspaper-sized).
