  • June 22, 2025, 07:03:07 PM
Author Topic: New Work Shop.  (Read 3095 times)
Offline Chris Wilson
New Work Shop.
« on: August 25, 2013, 08:46:57 PM »
Hi all,
         in about three weeks time I have the opportunity to fit out my new work space, kindly supplied by having a single car space from a double car garage, and intend to seriously build control line stunters.
The space is about 2.5 x 5.5 metres long and I want one long wall as a continuous work top, overhead cupboards for storage, under bench drawers for the same and behind me hanging space for models.
But where does one place the obligatory grinder, linisher, drill press and vice?  On that long run of a work top, separately to isolate vibrations or am I over thinking this?
Its just that I have had a work bench before with a vice mounted on each corner and it was just a pain to work around them all the time.
And lighting, can I do any better than a 5 metre strip of florescents directly overhead? Would it be better for lights to be under the overhead cupboards as well?
Ah, decisions, decisions. I suppose what I am asking is for work space solutions, stunt oriented, for that sized space.
Thank in advance, Chris.
MAAA AUS 73427
Re: New Work Shop.
« Reply #1 on: August 25, 2013, 09:47:43 PM »
 I'll suggest two separate benches, at the least. One dedicated only for building/framing/etc. and more delicate work, and then separate areas for the power tools, vice etc. In addition to those, a central "island" work station is a great thing as well. y1
Re: New Work Shop.
« Reply #2 on: August 25, 2013, 10:49:51 PM »
The two bench thing ....... makes sense, but the central island (in that sized space) is a no go.
Thanks for the advice.
MAAA AUS 73427
Re: New Work Shop.
« Reply #3 on: August 26, 2013, 06:08:07 AM »
You'll find building against the wall very annoying I think, I know I did. I have a 4' X 8' island bench. If I had that limited space, I would do something like 2' X 8' which is still a good working area. In fact it may be more space efficient because you can't place things out of reach. 2 feet would still allow a 3' passage between bench and walls. Definitely set your power tools up on a separate bench, not for vibration, but just to eliminate hard obstructions that are sure to be bumped causing damage to airframe parts.
Offline Clancy Arnold
Re: New Work Shop.
« Reply #4 on: August 26, 2013, 07:33:29 AM »
Chris
As for the lighting consider two rows of florescents.  One near ceiling height for general illumination and a second row under the overhead cabinets.  The second row eliminates the shadows from the cabinets and you and gives a more intense lighting right on the work area.
Clancy
Clancy Arnold
U/Tronics Control
Re: New Work Shop.
« Reply #5 on: August 26, 2013, 09:37:58 AM »
Make sure you hit us with pics of the new shop.
Re: New Work Shop.
« Reply #6 on: August 26, 2013, 10:12:16 AM »
An island makes life a lot easier but can be worked around. But you need as much light as you can pack in there. My shop is about 7 meters by 5 meters. I have 9 florescent lights and two spot lights for sanding.
Re: New Work Shop.
« Reply #7 on: August 26, 2013, 11:38:43 AM »
Yes,
I have 8 foot florescents every other joist and a 4 footer dropped down over my most used build area.
Offline Steven Kientz
Re: New Work Shop.
« Reply #8 on: August 26, 2013, 02:36:14 PM »
My shop is 10' by 20'. I have rolling workstations for the tablesaw, disc/belt sander and drill press. They all sit along one wall. My work bench is 8' by 30" wide, it is also on wheels. That way I can pull it out from the wall to access both sides. Below it are shelves, air compressor and one cabinet. My scroll saw sits on one end of the bench. Wheeled benches and storage units make life a lot easier in a narrow space. Just make sure to use 360 degree caster wheels. My router table has some fixed wheels on one end and it is a real chore to maneuver.
Steve Kientz
AMA 855912
Re: New Work Shop.
« Reply #9 on: August 26, 2013, 05:25:01 PM »
"You'll find building against the wall very annoying I think, I know I did. I have a 4' X 8' island bench. If I had that limited space, I would do something like 2' X 8' which is still a good working area. In fact it may be more space efficient because you can't place things out of reach. 2 feet would still allow a 3' passage between bench and walls. Definitely set your power tools up on a separate bench, not for vibration, but just to eliminate hard obstructions that are sure to be bumped causing damage to airframe parts."
Yep, that makes sense - just got to get my head around a 2' wide bench.
"Chris
Clancy"
That makes sense too.
"Make sure you hit us with pics of the new shop."
Sure will but please accept that it may be a month away before completion.
"An island makes life a lot easier but can be worked around. But you need as much light as you can pack in there. My shop is about 7 meters by 5 meters. I have 9 florescent lights and two spot lights for sanding."
I like the island option but it difficult in a gallery shaped space.
"Yes,
I have 8 foot florescents every other joist and a 4 footer dropped down over my most used build area."
8 ' - that's a very long tube mate.
"My shop is 10' by 20'. I have rolling workstations for the tablesaw, disc/belt sander and drill press. They all sit along one wall. My work bench is 8' by 30" wide, it is also on wheels. That way I can pull it out from the wall to access both sides. Below it are shelves, air compressor and one cabinet. My scroll saw sits on one end of the bench. Wheeled benches and storage units make life a lot easier in a narrow space. Just make sure to use 360 degree caster wheels. My router table has some fixed wheels on one end and it is a real chore to maneuver.
Steve"
Ah, rolling work stations!
Now that I can do and it may solve the island problem in a gallery space, thanks.
MAAA AUS 73427
Re: New Work Shop.
« Reply #10 on: August 27, 2013, 03:34:13 PM »
If you look at some woodworking sites you should find plans for power tool storage that have flip tops. That might cut down on how many work stations you need. Even if one tool only is mounted it would give you additional work surface when the tool is in storage.
Steve Kientz
AMA 855912
Re: New Work Shop.
« Reply #11 on: August 27, 2013, 04:33:26 PM »
"Chris
Clancy"
"Yes,
Steve"
2 4 footers end to end are cheaper and do the same thing.
Re: New Work Shop.
« Reply #12 on: August 27, 2013, 06:14:04 PM »
Hi Randy,
                I assume that you mean 2 4 foot lighting battens?
MAAA AUS 73427
Re: New Work Shop.
« Reply #13 on: August 27, 2013, 06:16:43 PM »
I would take that to mean girlfriends, but could be wrong!  LL~ Steve
Re: New Work Shop.
« Reply #14 on: August 27, 2013, 07:29:11 PM »
Hi Randy,
Yes
Re: New Work Shop.
« Reply #15 on: August 27, 2013, 07:29:55 PM »
The one 5'2" GF I have is plenty!!!!!
Re: New Work Shop.
« Reply #16 on: August 28, 2013, 02:31:05 PM »
I have a 4' X 4 tube fixture directly over my table.  There are 2 tube X 4' fixtures over my floor cabinets that line two walls.
BIG Bear
RNMM/AMM
