  • June 24, 2025, 11:37:40 PM
Author Topic: am i doing damage to the aerodynamics?  (Read 1900 times)
Offline steve pagano
« on: March 03, 2007, 06:55:24 PM »
I'm scratch building a patternmaster and i cut the fuse sides 1 inch longer then the plans.Can somebody tell me what i should do with the tail? Should i keep the distance between the trailing edge of the wing and the leading edge of the stab the same or move the stab back 1 inch also ?
Is moving the tail causing any damage to the aerodynamics or will it still fly the same?
 all replies appreciated
             thanks
« Last Edit: March 03, 2007, 08:29:59 PM by steve pagano »
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Re: am i doing damge to the aerodynamics?
« Reply #1 on: March 03, 2007, 07:21:30 PM »
Steve,
IF you move the stab back, it won't fly the same. May be better, may be worse, but not the same. sort of depends on the aerodynamics of the rest of the plane. If I were you, I'd build it according to plan. You know if flies well like that.
Re: am i doing damage to the aerodynamics?
« Reply #2 on: March 03, 2007, 09:50:04 PM »
What Randy said. Unless you're looking to redesign the aircraft, stay with the proven numbers. Moving the stab back is going to change the CG.
« Reply #3 on: March 03, 2007, 11:40:51 PM »
It will also change the response rate and the way the plane turns along with the effectiveness of the tail.
Offline Greg L Bahrman
« Reply #4 on: March 04, 2007, 12:28:22 AM »
             thanks
It doesn't matter much if the fuse is 1 in. longer to the rear, but as it has been said already, the relationship between the hinge line of the wing and the hinge line of the stab should remain the same as the plans. Oh, and by the way you should be measuring hinge line to hinge line. The PM is not only a proven design but a winning design and any changes would be hard pressed to improve on it. IMHO
« Last Edit: March 04, 2007, 10:24:58 AM by Greg L Bahrman »
Greg Bahrman, AMA 312522
Simi Valley, Ca.
« Reply #5 on: March 04, 2007, 07:37:04 AM »
             thanks
Hi Steve,
Two names:  Mike Rogers, Jose Modesto.  Put them in your speed dial.
;D
Bill <><
