  • July 03, 2025, 06:10:12 PM
Author Topic: StuntRib  (Read 1677 times)
StuntRib
« on: November 10, 2012, 10:20:35 PM »
Does anyone have a copy of Larry Cunningham's old program StuntRib? I had a copy but lost it when my hardrive went out.
Thanks.
Offline pipemakermike
Re: StuntRib
« Reply #1 on: November 11, 2012, 04:05:08 AM »
Hi Randy
I have a copy just change the file type from .doc to .zip and extract the files
Mike Nelson
Re: StuntRib
« Reply #2 on: November 11, 2012, 01:32:50 PM »
In a fit of curiosity, I tried to save and convert to zip file and had no luck doing that. Anybody able to help do this?  :-[ Steve
Re: StuntRib
« Reply #3 on: November 11, 2012, 01:47:24 PM »
Not convert in any way -- rename.
My window-fu is old, but you should be able to go to the containing directory in file manager, then right click the file name, then click rename, then delete the "doc" from the end and write in "zip".
Re: StuntRib
« Reply #4 on: November 11, 2012, 01:54:07 PM »
Steve,
I run three Macs and a PC.
Send me the file and I'll see what I can do with it.
Charles
Re: StuntRib
« Reply #5 on: November 11, 2012, 01:58:56 PM »
Well, sure, that's the first thing I tried. Doesn't work, 'cause it still says it's an MS Word Document.  I haven't found a way to fix that. I looked at posting it, and it now says: STUNTRIB.zip.doc, which is still useless. Could somebody convert it to a .zip and email it to me? Please? Pretty Please?  H^^ Steve   sbasser at yahoo dot com
Re: StuntRib
« Reply #6 on: November 11, 2012, 03:02:21 PM »
Even more important to posterity -- does anyone have source code?
Offline John Hammonds
Re: StuntRib
« Reply #7 on: November 11, 2012, 04:05:27 PM »
Hi Steve,
 Assuming you are on Windows it sounds like you may have "Hide Extensions for known file types" checked.
You can access it through "Control Panel" - "Folder options" - Then hit the "View" Tab. You should see the option a little way down. uncheck it and try again.
When you attempt to Rename the file you should get a Warning saying if you change the name extension the file may become unusable. (Just ignore it and click yes).
I can't send a mail because gmail does not allow zipped executables as attachments sorry..
TTFN
John.
BMFA 165249
Offline Geoff Goodworth
Re: StuntRib
« Reply #8 on: November 11, 2012, 04:38:37 PM »
Tim, Larry's computer is in safe hands and work is proceeding—albeit slowly—to reissue the plans for Mo'Best and to kit Mo'Best and Mo'Beast.
At this point, nothing is being done with the StuntRib code but I believe that it is safe.
Re: StuntRib
« Reply #9 on: November 11, 2012, 06:01:30 PM »
I had no problems extracting it using Ark (sorry, I have a Linux system). Works fine and thanks!
Larry told me he lost the source code for Stunt Rib. He was working on a new program to allow plotting for elliptical wings both in planform, ribs and spars. I have an early version, but it wasn't functional yet. Pretty cool though. Hopefully, someone has the new program code.
Re: StuntRib
« Reply #10 on: November 11, 2012, 07:44:06 PM »
Hi Steve,
TTFN
John.
Thanks for your help, John! I got it converted & now have to figure out what to do with it and maybe how to make it work.   H^^ Steve
Re: StuntRib
« Reply #11 on: November 11, 2012, 07:50:32 PM »
Steve,
I've used it before. Pic a NACA airfoil to use then just take measurements from the plans and export to .DXF file. then you can import each file in a CAD program and print them out (unless you happen to have a printer attached to the lpt port then you can print them out directly. Just read the Read Me file and it gives a pretty good explanation. I needed it because I'm building a true elliptical wing (both planform and vertical taper). Stunt Rib make it easy to come up with ribs for such a wing.
Offline Robertc
Re: StuntRib
« Reply #12 on: November 12, 2012, 11:51:31 AM »
I would be the one with Larry's computer and all his files...and there is a lot of them.  There is a small core group working to keep
Larry's work out there.  I have seen the Stunt Rib files on his computer, but have not checked to see if he finished the latest version.
Guess I'll look into that.
Robert Compton
Re: StuntRib
« Reply #13 on: November 14, 2012, 12:06:03 PM »
Be great if he did. It's a very useful program.
