  • July 16, 2025, 09:30:54 AM
Author Topic: Non Foaming CA Activator  (Read 1480 times)
Mike Griffin
« on: May 19, 2014, 02:15:51 PM »
Has anyone found a CA accelerator/Activator that will not foam up and harden when sprayed on CA?
Re: Non Foaming CA Activator
« Reply #1 on: May 19, 2014, 02:42:51 PM »
I use the Hot Stuff aerosol activator. It will foam the CA if applied too heavy but it is much easier to control than the old spray pump type. I think most brands of CA make the aerosol activator now.
Derek
Mike Griffin
« Reply #2 on: May 19, 2014, 05:32:01 PM »
Thank you Derek.  Have not seen you or your dad in a long time since we moved back to New Orleans....hope both of you are doing well.
Offline Tony Drago
« Reply #3 on: May 21, 2014, 06:06:00 PM »
Stay away from the kickers.
  Let the CA's cure at their own pace. So it will take a few minutes or so longer.
 You will have a much stronger bond.
Mike Griffin
« Reply #4 on: May 21, 2014, 09:54:23 PM »
Thank you Tony.  I did not realize the kicker weakened the joint.
Offline Phil Krankowski
« Reply #5 on: May 28, 2014, 08:17:59 PM »
Rubbing alcohol will kick CA without foaming, but the CA will blush heavily (white, soft residue).  Notably slower than other kickers I have used, but much faster than not using a kicker at all.  At $1 per pint from the local drug store it is also notably cheaper than any other kicker I have used.  I have noticed no difference between the 70% and the 99%.
No I don't go through THAT much, I decant into a small fine mist spray bottle, and the stock bottle gets used as rubbing alcohol.
The joint remains stronger than the wood I am bonding so I am satisfied.
Phil
