  • July 18, 2025, 08:53:28 AM
Author Topic: Wing?  (Read 5814 times)
Offline Larry Wong
Wing?
« on: December 23, 2012, 09:06:30 AM »
What does this do?  It's used in R/C Pattern planes  This might be a good question from new member Chip Hyde. #^ #^ ??? ???
Larry
Offline don Burke
Re: Wing?
« Reply #1 on: December 23, 2012, 10:06:31 AM »
Maybe for stability in hovering/very high angle slow speed type manuevers.  Something only the Bi-slob type worries about doing. But it also looks too small to have slow speed effect.
It could also be like the famous "chrome eagle" at Indianapolis.  It was said that if someone at Indy had a chrome eagle on their car and went fast, everyone would end up rushing back to their garage to install one.
don Burke AMA 843
Menifee, CA
Mike Griffin
Re: Wing?
« Reply #2 on: December 23, 2012, 10:34:15 AM »
Hi Larry
This is the first time i have ever seen this in a model.  I would really like to know what its purpose is too.
Re: Wing?
« Reply #3 on: December 23, 2012, 10:56:52 AM »
Without seeing the whole ship I would guess that is Kenny Stevens' airplane.  Maybe he'll jump in here if he is a member.  I have discussed it at length with him at a couple of contests, but hesitate to venture the facts as he told me for fear of twisting it around.  The old memory ain't what it used to be.
Re: Wing?
« Reply #4 on: December 23, 2012, 11:09:07 AM »
Aid in the flare at landing?
Charles
Offline MarcusCordeiro
Re: Wing?
« Reply #5 on: December 23, 2012, 11:19:44 AM »
Hi Larry
So that makes one more... ??? ??? ??? ??? ???
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Re: Wing?
« Reply #6 on: December 23, 2012, 11:37:29 AM »
In case the main wing folds up in flight, you will have a back-up?
F.C.
(name with held for fear of reprisal)
Offline Mike Haverly
Re: Wing?
« Reply #7 on: December 23, 2012, 11:47:56 AM »
What does this do?  It's used in R/C Pattern planes  #^ #^ ??? ???
Don't know abut RC but it gives a CL guy one more thing to fix when it breaks off.  I asked Kenny about it and I'm pretty sure he said he couldn't see a big improvement.  His new one this year didn't have one.
Re: Wing?
« Reply #8 on: December 23, 2012, 12:20:49 PM »
I googled and found another shot of the same model, but it was taken early in the morning.
Re: Wing?
« Reply #9 on: December 23, 2012, 01:05:39 PM »
He doesn't want to tell you the  secret really behind the little wing.   Really it is there to make people ask questions about it so he can give each one a different answer.   It does blow the mind, cause I don't beleive the R/C guys have an answer.
Offline Lynn Weedman
  • x47weed (Lynn Weedman)
Re: Wing?
« Reply #10 on: December 23, 2012, 01:21:49 PM »
Vortex Generator / diffuser    Vortex Generator / diffuser    Vortex Generator / diffuser    Vortex Generator / diffuser S?P
Lynn Weedman
Re: Wing?
« Reply #11 on: December 23, 2012, 01:26:48 PM »
Vortex generator.  My guess is that it  keeps the flow attached to the vertical stabilizer at high wing angles of attack.
Re: Wing?
« Reply #12 on: December 23, 2012, 01:53:30 PM »
only a wind tunnel test will reveal the true effects that are created in relation to the control surfaces and the attitude and speed of the aircraft. The full size jet type aircraft that I address issues on everyday have these types of devices installed at different locations and have different various designs for the type of vortex effect needed.
Lynn Weedman
Re: Wing?
« Reply #13 on: December 23, 2012, 01:58:08 PM »
I can't believe no one has figured out what its for by now. It's there very obviously, to make his ship look like a super cool 2M pattern ship.
Of course he is going to need split ailerons, split actuating rudders, iso engine mounts, hattori spring loaded pipe, or plettenberg gear drive, split front fuse, recessed landing gears under the pipe, naca 640-012 root and tip sections,about 1000sq. of wing area, a fuselage 12 to 14 inches high and about 78 inches long, forced air cooling to the drive system, dual drives to the elevators, push-pull on the rudders and multiple condition radio programming with laptop download,to make that canalizer REALLY work.  LL~
« Last Edit: December 25, 2012, 10:49:05 PM by proparc »
Re: Wing?
« Reply #14 on: December 23, 2012, 02:09:20 PM »
Well.......... Sure makes for a good convesation piece.
could be a scaled down spoiler from the TOO FAST TOO FURIOUS movie  S?P LL~ LL~ LL~
Lynn Weedman
Offline Chuck_Smith
Re: Wing?
« Reply #15 on: December 23, 2012, 03:24:25 PM »
If I was a bettin' man, I'd guess he wanted the vertical area for knife-edge manuevers, and the wing increases it's effective span regardess of which side is up.
If so, pretty ingenious.
AMA 76478
Offline Chuck_Smith
Re: Wing?
« Reply #16 on: December 23, 2012, 03:26:35 PM »
If so, pretty danged ingenious. If not, that's what he should be doing with it!
AMA 76478
Re: Wing?
« Reply #17 on: December 23, 2012, 03:47:45 PM »
Then why isn't there one on the bottom, too?
Offline Chuck_Smith
Re: Wing?
« Reply #18 on: December 23, 2012, 03:50:19 PM »
It would drag on the ground!
AMA 76478
Re: Wing?
« Reply #19 on: December 23, 2012, 05:17:52 PM »
My guess is the fact that you asked the question has revealed its true purpose, was probabably taken on April 1st
Offline Chris Wilson
Re: Wing?
« Reply #20 on: December 23, 2012, 06:43:23 PM »
Apparently with the Kenny Stevens model it is to "assist in overhead maneuvers " by giving more lime tension in vertical eights, overhead eights and the hourglass.
http://www.docstoc.com/docs/100257056/Navy-Carrier (page 6 in the inset field).
MAAA AUS 73427
Offline SteveMoon
    • www.ultrahobbyproducts.com
Re: Wing?
« Reply #21 on: December 23, 2012, 08:34:49 PM »
Chris is exactly right. That little wing is most effective at generating
extra line tension at the top of the hourglass. They are very common
on RC Pattern planes, and as mentioned before assist in knife edge
maneuvers by cleaning up the airflow over the vertical stabilizer and
making it more effective.
Later, Steve
Dennis Leonhardi
Re: Wing?
« Reply #22 on: December 23, 2012, 10:33:52 PM »
F.C.
Laughing my butt off Floyd!  Will you be appearing at any of the comedy clubs in Minnesota?
Dennis
Offline afml
Re: Wing?
« Reply #23 on: December 24, 2012, 03:29:26 AM »
C'on Guys!
TWO WINGS.....
It's a biplane!! LL~ LL~
Chis has the right answer...
"Tight Lines! &  a Blessed and VERY Merry Christmas! H^^
Wes
Wes Eakin
Offline dankar
Re: Wing?
« Reply #24 on: December 24, 2012, 09:21:13 AM »
I like it.  Looks cool, and going to install one on my Magician .35 just for sake of guys asking what its for. Maybe put it on my Sterling FokkerD V11 [ Thanks Unka Mikey !!} and now have Fokker tri-plane........>> LL~ LL~ LL~
Offline Serge_Krauss
Re: Wing?
« Reply #25 on: December 24, 2012, 11:50:32 PM »
As Posted prviously, it's a device used by top RC Pattern flyers for better knife-edge performance. MA has covered its use.
Re: Wing?
« Reply #26 on: December 25, 2012, 12:08:38 AM »
  I gotta ask the question then, how do our models know when they are in "knife edge?" A properly trimmed stunt model should already pull nearly the same all over the circle, and because it is tethered, it is always in an optimum attitude for knife edge flight no matter what it's position in the hemisphere. The vertical stab of a C/L stunt model is not used like the vertical stab and rudder on a pattern ship. The effects of drag and gravity are different on a c/l stunt model than on a R/C pattern ship trying to track a straight line parallel to the ground. And because of the constant flight attitude of the center line of a stunt model in the yaw axis, if this appendage does indeed help the flight of the airplane, it should be effective at all parts of the hemisphere, I would think.
   I just wrapped the last present and put it under the tree and now I'm gonna lay my head down and wait for Santa to come. MErry Christmas to all my friends in Stunt Land, and may we all have a Happy and Healthy New Year!!! H^^
Offline Dennis Moritz
Re: Wing?
« Reply #27 on: December 25, 2012, 03:17:50 AM »
I thought it had something to with vertical CG. Where's Kenny Stevens. He'll tell you. Woops. Kenny Stevens has spoken.
« Last Edit: December 25, 2012, 04:07:11 AM by Dennis Moritz »
Offline RC Storick
Re: Wing?
« Reply #28 on: December 25, 2012, 06:17:19 AM »
with the low speeds we fly at I would bet the airplane would perform the same as if it was there or wasn't there. So zip besides it being a gadget to make people ask questions and shade the imagenary pilots head. Sorry Kenny JMHO
It MIGHT do something on a RC plane MIGHT. But if it was of significant value why are they not on jet fighters?
Re: Wing?
« Reply #29 on: December 25, 2012, 06:31:40 AM »
I've seen them on the trunks of Limos.  n~
Charles
Re: Wing?
« Reply #30 on: December 25, 2012, 07:23:28 AM »
I'm gonna put 'em on my cars and trucks.  I need a good place to set my coffee cup while I open the door.
Re: Wing?
« Reply #31 on: December 25, 2012, 09:17:51 AM »
Charles
 LL~ LL~ LL~ LL~
Offline Herb Calvin
Re: Wing?
« Reply #32 on: December 25, 2012, 12:18:38 PM »
reply to arojet: Those things on back of limos are t.v. antennas I think. ???
steven yampolsky
Re: Wing?
« Reply #33 on: December 25, 2012, 04:36:59 PM »
The idea of the winglet is to stabilize the airflow around the rudder during the knife edge. This is "old school" solution, AKA 2011. 2012 models feature a retractable fin. Apparently the fixed winglet generates undesired vortexes in level flight maneuvers.
At least that's what I gather from MA rag. Yes, I read other sections beside CL Stunt and Engines.  ;D
Re: Wing?
« Reply #34 on: December 25, 2012, 08:10:45 PM »
For yourself and your release buddy.
Re: Wing?
« Reply #35 on: December 25, 2012, 08:24:36 PM »
It flaps.
Offline John KruziK
Re: Wing?
« Reply #36 on: December 25, 2012, 08:42:20 PM »
We used to put them on all our planes, its to carry plane, kind of like a six pack.
AMA 874027
Offline Mike Keville
Re: Wing?
« Reply #37 on: December 25, 2012, 09:20:21 PM »
 LL~  LL~  LL~ You guys have been too heavy into the egg nog today....
Offline bill bischoff
Re: Wing?
« Reply #38 on: December 25, 2012, 09:33:50 PM »
Steve, why do RC pattern airplanes need more line tension?
Re: Wing?
« Reply #39 on: December 25, 2012, 10:26:23 PM »
You don't really think that they are going to trust several thousand dollars worth of model airplane equipment to just a radio signal that they can't even see-do you?
Re: Wing?
« Reply #40 on: December 26, 2012, 04:16:06 AM »
 LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~
Marcus
Aces High!
