Last year while practicing Saturday evening at KOI, while transitioning from the top loop to the bottom loop of a vertical eight, my Vector 40 just simply would not turn when I got about 1/4 way throught the down portion of the bottom loop, and went in. After studying theparts I foune out that the top brass ferril holding the bellcrank bushng in place had a bad solder joint allowing the bushing to slide up the rod and caused the bellcrank to hang up on the rib slot it passes through. Funny thing, occasionally during previous flights would feel a slight snag once and a while, but it would go away, and so I never paid much attention to it. Thik the plane was trying to tell me something?
Phil
