Thanks for the replies, here's what I've found so far...
I'm still not sure what this stuff is, but its not like anything I've dealt with before. It penetrates like a mother, and is soft but brittle...
Weird.
I cut the fillets between the parts with a sharp #11 blade, and then followed by carefully prying apart with a #2 X-acto handle with the large curved carving blade. I also used some minor brute force.
My conclusion is that the Nobler ARF front end is built a lot stronger then it appears. The plywood firewalls are keyed into the plywood doublers, and here's the part that threw me... The doublers are keyed, and the motor mounts key into them. The mounts as they extend out the front of the fuselage look like 5/16" x 7/16", then they taper back to 1/8" x 7/16" at the rear, but in reality the taper is more like 1/4" x 7/16" because 1/16" of the width is keyed into the plywood doublers. Hope that makes sense. Seperating the oak(?) motor mounts from the fuselage sides took quite a bit of balsa along for the ride. At any rate, even with minimal and substandard adhesives the motor mounts, front doublers, and the firewalls, aren't going anywhere. Much the same as the Veco kits with everything keyed and the lesser cements of the time period.
I'm already on the downhill stretch. I've got new 5-ply birch firewalls cut, an authentic Nobler landing gear bent, 3/8" x 1/2" hard maple motor mounts cut, and it's slowly going back together.
