I seem to recall seeing Dirt using one of these tanks kicked over, with the "top" tube becoming the uniflow and "foot" against the fuselage? I contemplated doing this when I put a Hayes tank on the blue meanie, but decided it would be a PITB to fill with fuel (hold plane with inboard tip down). It ran well without uniflow, but I never could figure out a cure for the windup in the round outside loops. Everything else was good enuf, ...as long as the tacho was used to set launch rpm...
Close, real close. But different models, different tanks. Still (pukey) profiles however.
Models are of
Wimpact series developed by Derek Moran and myself. Tanks used are the Hayes Slimline 4-oz and (sometimes) the 6-oz number. Models are powered by piped O.S. 25FPs. MACS aluminum pipes are preferred. No pipe pressure. APC 10-3 props. Largest of my three models is 450 square inches and they are merely scaled
Impacts then converted to profile configuration.
As to the tanks used, Steve is right in that they are laid on their side with vents to right of model. Of course this mildly complicates fueling procedure but raising nose of model takes care of the issue.
As the tanks work superbly this is not anything of consequence. How superbly? Don't believe me. We were flying in Salem, none other than Don McClave was one of the judges. As the model landed Don couldn't wait, actually coming into the circle as we were removing the model. "That thing runs
exactly the same for the whole flight! What tank are you using?" While initially he didn't seem to believe it was an RC clunker it wasn't long before he was experimenting with similar setups. (Don had always been a hard-core fan of metal tanks.)
Dan
