  • June 16, 2025, 02:04:52 PM
Author Topic: No Action??????  (Read 2915 times)
Offline Chuck Feldman
No Action??????
« on: April 05, 2006, 09:01:20 AM »
WWWARBIRD  says there is not enough posts. So I am going to write a post about something.
Number one is that this is the best Forum and I believe the leaders are doing a good job.
Heres a question for you boys.
Did any of you play with swing gliders as a kid?
Whats a swing glider? It is a balsa glider with a washer on one wing tip and a string on the other. Now you would just swing it around. It was a good toy, was fun to make and it was cheap to make. They where good wind fliers.
Chuck Feldman
AMA 15850
Re: No Action??????
« Reply #1 on: April 05, 2006, 11:59:23 AM »
Never did anything quite like that, but I did go through a short phase involving Peck ROG's...  Nothing quite like flying an ROG outside.  Got to retrieve it off of at least three different roofs.  Also I put together a small extremely overweight glider out of scrap balsa.  With about 2oz of lead in the nose it would really sail if you got some momentum in the launch.  Think I gave up on that one the first time it sailed head-on into the side of the garage.  I'll never forget the sound of 2oz of lead hitting siding.  I goofed around with a lot of stuff in the backyard growing up.
Offline Jim Thomerson
Re: No Action??????
« Reply #2 on: April 05, 2006, 12:07:08 PM »
There is an article in an old MAN , Threadit,  about making a CL swing airplane flown on a loop of thread.  The thread goes through lead tubes on the wing and back to a toothpick piece stuck through the elevator for a pull-pull.  Make the loop about the length to the floor with you hand above your head.  No handle , just hold the end of the loop around your hand and do figure 8's, loops and inverted.  I have accumulated various dime-store gliders with the idea of making threadit's out of them, but they are still NIP ::).  I think this would be a fine way for a new CL flier to learn how to do various maneuvers real cheap.
Offline Tom Dugan
Re: No Action??????
« Reply #3 on: April 05, 2006, 02:14:53 PM »
When I was young, all we could afford was the washer and a piece of string.  Neither glides very well and hurt like he!! when my sister took it from me and hit me me with it.
Long ago I had a toy helicopter similar to a vertibird but a bit more elaborate.  It was made by Marx or Hasbro.  It was tethered by a counter balanced rod.  The Pilot controlled its up, down, forward, or reverse motion by two control sticks (collective & cyclic).  It even had an operable hoist for those emergency rescues.
I have never seen one since except the cheaper Vertibird.  I believe this toy caused my interest in flying which led me to control line, Hueys in the Army, and now back to control line.
Thomas
« Last Edit: April 07, 2006, 09:43:23 AM by TJDNC »
Offline L0U CRANE
Re: No Action??????
« Reply #4 on: April 05, 2006, 02:57:10 PM »
Chuck,
I have occasionally flown some whip-powered models - which are just a bit more complicated than what you describe.
Might have been AJ once offered a whip-control model. There've been plans for these in magazines. I think there's an F84 semi-scale plan at Dave Fritzkie's site.
With a short dowel (24-36" with a line guide) to extend 'reach', these can be flown on surprisingly long lines, and with elevator control, can be purt-near fully aerobatic.
\BEST\LOU
Re: No Action??????
« Reply #5 on: April 05, 2006, 04:35:22 PM »
Blackhawk Models has several whip control kits.  I have one ready to go.  DOC Hollliday
Re: No Action??????
« Reply #6 on: April 07, 2006, 07:31:12 AM »
Yes I have made a few swing gliders. But we call them whip-its.
Both my boys had them also. I think I saw one laying in the garage the other day, still on the fishing pole.
