  • July 18, 2025, 06:37:27 AM
Author Topic: Nitromethane Color Question  (Read 6607 times)
Offline Bruce Reynolds
    • Dayton Buzzin' Buzzards Home
« on: March 15, 2010, 10:30:21 AM »
Guys,
We purchased some nitro from a local source to mix up some home-brew.  We didn't pay much attention to it until we got home and noticed that the color was more of a light golden brown verses the more yellowish-sort-of-lemonade color we remembered from back in the day of rolling our own fuels.
Does anyone have any knowledge on whether the color indicates a problem with the nitro, or whether there are different grades, or should we just shut up and mix it?  ;D
Thanks for any info.
Re: Nitromethane Color Question
« Reply #1 on: March 15, 2010, 10:58:28 AM »
Wikipedia, which must be accurate because anyone can edit an article, lists nitromethane as a colorless liquid (see http://en.wikipedia.org/wiki/Nitromethane).
My suspicion is that the color in your nitro was most likely specified by a marketing guy, not an engineer.
Offline Steve Fitton
« Reply #2 on: March 15, 2010, 12:07:21 PM »
Pure nitromethane is indeed a colourless liquid.  Back in my lab days, we had to do some tests on nitro for a drag racing organization, at the time comparing relative purities of US made vs Chinese made nitro.  The US made was colorless and typically exceeded 99% purity, the Chinese nitro was amber in color and typically around 96% purity, with water being detectable as well as a host of organic compounds.
Offline Robert Schroeder
« Reply #3 on: March 19, 2010, 11:41:35 PM »
Yeah, and now the only source is chicom.
Bob from NWO:  If it ain't broke, fix it till it is!
AMA 15083
Offline Mike Lauerman
« Reply #4 on: March 20, 2010, 12:01:34 AM »
Our current administration is making every effort to keep dangerous chemicals out of our incompetent hands. Thank God for a wizard for a president.
« Reply #5 on: March 20, 2010, 10:48:07 AM »
Yellow dye in nitro is an indicator that turns blue if it's contaminated with something that could make it dangerous.  If it's contaminated by an amine or a base, the nitro forms an azide (as I remember), becomes shock sensitive, and could blow up.   Most nitro I've found has the dye; some doesn't.   In a previous nitro shortage-- maybe 20 years ago-- I got some bad Chinese nitro.  It turned brown and dissolved metal.  Chinese nitro I've gotten lately has been just fine.  I got the last batch from Mark Smith in Arizona.  Density was spot on for pure nitro.
Offline Greg McCoy
  • flying tiger B24 gunnery school patch Laredo
« Reply #6 on: March 21, 2010, 11:07:22 AM »
Confirming Howard's info, the MSDS calls it a colorless liquid, made unstable by amine and acid contamination.
Safety data for nitromethane
Glossary of terms on this data sheet.
The information on this web page is provided to help you to work safely, but it is intended to be an overview of hazards, not a replacement for a full Material Safety Data Sheet (MSDS). MSDS forms can be downloaded from the web sites of many chemical suppliers.
General
Synonyms: nitrocarbol
Use: detonating agent, fuel, solvent, gasoline additive
Molecular formula: CH3NO2
CAS No: 75-52-5
EC No: 200-876-6
Annex I Index No: 609-036-00-7
Physical data
Appearance: Colourless oily liquid
Melting point: -29 C
Boiling point: 100 - 102 C
Vapour density: 2.1
Vapour pressure: 27.8 mm Hg at 20 C
Specific gravity: 1.136
Flash point: 36 C
Explosion limits: lower 7.3% upper n/a
Autoignition temperature:
Critical temperature: 315 C
Critical pressure 62.3 atm
Water solubility: substantial
Stability
May detonate if sensitized by amines, alkalies, strong acids, high temperatures or adiabatic compression. The dry alkali or amine salts are shock-sensitive and the sodium salt ignites on contact with water. Incompatible with amines, strong acids, strong bases, strong oxidizing agents, strong reducing agents, copper, copper alloys, lead, lead alloys. Flammable. Store under an inert atmosphere.
Toxicology
Harmful if swallowed, inhaled or absorbed through skin. Irritant. May cause cyanosis, which can be delayed up to 4 hours. Typical TLV 100 ppm.
Toxicity data
(The meaning of any abbreviations which appear in this section is given here.)
IHL-MUS LCLO 18 g/m3/2h
IVN-RBT LDLO 750 mg kg-1
ORL-RAT LD50 940 mg kg-1
ORL-MUS LD50 950 mg kg-1
Risk phrases
(The meaning of any risk phrases which appear in this section is given here.)
R5 R10 R20 R21 R22.
Transport information
(The meaning of any UN hazard codes which appear in this section is given here.)
Hazard class: 3.0. Packing group: II. UN No 1261.
Personal protection
Must not be used without carrying out a prior risk assessment. Safety glasses (face mask if working with anything other than trivial amounts) and good ventilation required.
Safety phrases
(The meaning of any safety phrases which appear in this section is given here.)
S41.
[Return to Physical & Theoretical Chemistry Lab. Safety home page.]
This information was last updated on May 8, 2009. We have tried to make it as accurate and useful as possible, but can take no responsibility for its use, misuse, or accuracy. We have not verified this information, and cannot guarantee that it is up-to-date.
Note also that the information on the PTCL Safety web site, where this page was hosted, has been copied onto many other sites, often without permission. If you have any doubts about the veracity of the information that you are viewing, or have any queries, please check the URL that your web browser displays for this page. If the URL begins "http://msds.chem.ox.ac.uk/" the page is maintained by the Safety Officer in Physical Chemistry at Oxford University. If not, this page is a copy made by some other person and we have no responsibility for it.
AMA 77370
Tags: nitro  fuel
