  • June 28, 2025, 05:29:05 AM
Author Topic: PT -19 --- Check those lines!!!  (Read 2519 times)
« on: June 03, 2009, 10:26:24 AM »
We had a new guy come out the field this past weekend and he had a brand new PT-19 with a Evo .36. Nice looking setup.
But the lines were not crimped that came with the kit! He said there was nothing in the instructions that told him to crimp them and he did not know that they needed to be. The thimbles were set the wire was pulled thru the sleeve, already to crimp but either end of the lines were not crimped.
Then yesterday Kelly Wilson went by the LHS and checked the two that were on the shelf. Same thing. He called the vendor and they said that the lines should be crimped.
So double check the lines if you have one still in the box.
Offline Charlie Pate
Re: PT -19 --- Check those lines!!!
« Reply #1 on: June 03, 2009, 11:00:14 AM »
He,s lucky to have someone like you to help him.
By the same token , you,re lucky to have another flyer.
A simple case of win,win. #^
Offline Mike Palko
« Reply #2 on: June 03, 2009, 11:05:42 AM »
The leadouts need to be wrapped/cripmed as well. On my PT-19 the leadouts were only crimped at the bellcrank.
Offline Scott Hartford
« Reply #3 on: June 03, 2009, 12:59:14 PM »
Actually I don't think they're supposed to be crimped. They are assembled with CA in the sleeves. I would crimp them, but they have been flown like that and lived through it.......
« Reply #4 on: June 03, 2009, 01:40:15 PM »
Well when he called HH they told him they should have been crimped from the factory. When I expected them the sleeve slid right up the line and the thimble came right off in my hand.
Offline Mike Palko
« Reply #5 on: June 03, 2009, 04:19:59 PM »
I believe you're right. If I rememeber correctly this was mentioned in the long PT-19 thread, but I have a feeling it has been lost. FWIW, My leadouts came apart so easily (they were not crimped, but were glued) that I didn't have to cut the ends off to redo them. It's a quick fix, hopefully the bellcrank connections hold!
Offline Garf
    • Hangar Flying
« Reply #6 on: June 03, 2009, 04:40:52 PM »
I have a detailed thread on this plane at the linked location. It includes my findings on the lines.
http://hangarflying.proboards.com/index.cgi?board=wire&action=display&thread=2870
Offline Keith Spriggs
    • khspriggs
« Reply #7 on: June 03, 2009, 05:59:14 PM »
Excellent review, Garf. You take a fantastic close up picture.
« Reply #8 on: June 03, 2009, 07:41:57 PM »
Nice catch Paul, you may have saved us a CL'er!   H^^  8)
Offline Garf
    • Hangar Flying
« Reply #9 on: June 03, 2009, 07:48:13 PM »
I have had a lot of practice taking pictures for my Ebay listings. Check the pics on the ST NV problem thread.
Offline J.B. Morrison
« Reply #10 on: June 06, 2009, 08:25:54 PM »
Hey All;
I'm the guy with the PT-19 Paul mentioned. Mea Culpa for not crimping the ferrules on the lines. 30+ years ago when I last built and flew C/L, crimping them was the norm. I inspected them when I got the kit, and noticed no crimps. Tugged on the lines, they felt secure. Looked at the instructions with the kit, nothing about crimping them. I remember reading on this and another forum about using CA glue in the ferrules in lieu of crimping, so I assumed they were adequate out of the box. Paul and I gave them a good look before flying the airplane, but obviously they weren't secured as the came loose after flying only 1/2 of a circle, with disasterous results!
The good news is that I called HorizonHobby/Hangar9 the day after the crash, and after telling them about what happaned, I was told to box up the wrecked PT-19, Evo.36, send it back to them, and a new kit with engine while be sent as an exchange!
Also, I got my sons (12 and 15) flying this week on the old FliteStreak Trainer that Paul gave us several months ago for us to rebuild and use as a beater!
John Morrison
Offline Richard Grogan
« Reply #11 on: June 06, 2009, 08:32:01 PM »
I am really surprised that they let that get past QC. Amazing  HB~>
Long Live the CL Crowd!
                  AMA 85745
« Reply #12 on: June 06, 2009, 08:55:01 PM »
Well John's was not the only one. Two more ARF's were at the LHS and were the same way. Kelly W. was at the field the day John's went in. He took the lines out of the kits at the LHS and took them home to fix them.
« Reply #13 on: June 07, 2009, 02:07:29 PM »
So there was no trace of CA in the tubes??????
« Reply #14 on: June 10, 2009, 07:47:55 AM »
AllGot an e-mail from Hangar 9 this morning (Wendsday, 10 June) that the replacement PT19 kit with Evo.36 has already been shipped #^! Great service, so far.
John Morrison
