  • July 26, 2025, 06:41:35 AM
Author Topic: Nitrate paint  (Read 1226 times)
Nitrate paint
« on: February 17, 2009, 05:46:14 PM »
  Can castor oil be added safely to nitrate to reduce the amount of shrinking? I have added castor oil to butyrate with no problems but was wondering about using it on nitrate for areas that don`t need the shrinking quality of this paint but still want to use it to fill the grain.
Offline billbyles
Re: Nitrate paint
« Reply #1 on: February 17, 2009, 09:49:45 PM »
Hi Juan,
While I imagine that the reason you asked about plasticizing nitrate dope is because you have the tautening type on hand, nitrate dope is readily available in non-tautening.  When I use nitrate (admittedly not often and then mostly on full-scale airplanes) if I have only tautening nitrate on hand I use good old Dave Brown's "Flex-All" to plasticize it.  Works fine and even on a full-scale airplane it doesn't take much.
Bill Byles
AMA 20913
So. Cal.
Re: Nitrate paint
« Reply #2 on: February 18, 2009, 06:09:36 AM »
   Thanks guys I`m just trying to avoid the starving horse look in a fuse with compound curves and light wood.
