Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 11, 2025, 01:56:35 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
Nitrate dope and Lusterkote
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Nitrate dope and Lusterkote (Read 1694 times)
Phil Coopy
Trade Count:
0
Captain
SHADE TREE MECHANIC, NO ENGINEER
on:
August 02, 2006, 10:45:51 PM »
Just found out the hard way that Lusterkote doesn"t stick to nitrate dope without primer. Question does it work with primer? Possibly if I mix in some MEK?
Phil
Logged
Leester
2014 Supporters
Trade Count:
0
Admiral
Re: Nitrate dope and Lusterkote
Reply #1 on:
August 03, 2006, 01:42:44 AM »
I've used Butyrate without primer and had no problem with Lustrekote. I haven't tryed Nitrate with or without primer.
Logged
Leester
ama 830538
Phil Coopy
Trade Count:
0
Captain
Reply #2 on:
August 03, 2006, 07:07:25 AM »
Well I'm back to the nitrate coat....the adhesion was so poor that the Lustrekote peeled off like a layer of plastic wrap. Fortunately the only part I painted was the fuse on my Ringmaster (before assembly). The paint job looked great until I pulled off some masking and the color basecoat came with it. I'm gonna' go conventional and use dope this time.
Phil
Logged
RC Storick
Forum owner
Administrator
Trade Count:
0
Admiral
The finish starts with the first piece of wood cut
Reply #3 on:
August 03, 2006, 07:27:56 AM »
I have stated this a few times. Lacquers are chemical bond and enamels are mechanical bond. You must have a primer between the two. (or a trick)
Logged
Charlie Pate
Trade Count:
0
Commander
Reply #4 on:
August 04, 2006, 04:56:36 PM »
Where does epoxy fit (what cate ???gory)?
Logged
RC Storick
Forum owner
Administrator
Trade Count:
0
Admiral
Reply #5 on:
August 04, 2006, 05:11:06 PM »
Epoxies are a chemically activated mechanical bond type paint. Most Epoxies are activated with MEK. The MEK is sometimes hot enough to act as a chemical bond. So you get both property's in one application.
This is one reason I use lacquer thinner in my Urethane applications.
Logged
Charlie Pate
Trade Count:
0
Commander
Reply #6 on:
August 04, 2006, 08:21:49 PM »
Thanks for the info.
Logged
wwwarbird
2016 supporter
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Reply #7 on:
August 08, 2006, 04:29:43 PM »
Lustrekote goes over dope just fine, but you are correct, you cannot dope over Lustrekote, it won't stick and you have a mess.
Sparky knows all the techy info on this one.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
