  • June 24, 2025, 12:26:16 PM
Author Topic: Line length  (Read 1703 times)
Offline Jim Pollock
Line length
« on: February 16, 2010, 04:47:51 PM »
I'm not sure where to put this but:
While using line length to trim a model, how short can you get the lines before the lap times and shortness of the hemisphere makes things look well, wrong!
Jim Pollock,   :!
Re: Line length
« Reply #1 on: February 16, 2010, 04:57:19 PM »
Depends on the size of the plane. A half A looks fine on 30 foot lines. Paul Walker's B-17 looked a little cramped on 70 foot lines.
Dave Adamisin
Re: Line length
« Reply #2 on: February 16, 2010, 08:29:15 PM »
Isn't the minimum legal center to center (plane to handle) 60 feet for anything larger than class A?
Re: Line length
« Reply #3 on: February 17, 2010, 05:02:45 PM »
I think the only minimum is the 42 feet for 1/2A if I remember right.   I used to fly 1/2A on 35 X .012 cable until both cables broke when the plane hit the deck.  Line length depends on how comfortable you are with the flight of the airplane.
Dave Adamisin
Re: Line length
« Reply #4 on: February 17, 2010, 06:29:17 PM »
Hi John. I was surprised enough by what you said that I went to the AMA site to check the CLPA rules. I "remembered" that the line length was dictated by engine displacement class and that back in the day we had a minimum length cl/cl of 60 feet. The rule book now just states the requirements for diameter based on weight and lists the lengths as 25 - 70 feet. You are of course correct. Thanks.
Re: Line length
« Reply #5 on: February 20, 2010, 09:16:19 AM »
Also remember that is center of handle to center of the plane.  On thE single engine planes, some people use the prop nut or spinner as COP.  I remeber a couple of people having to cut their lines on PA one year.  So check your event rules or what ever class your plane might fit.
