  • July 04, 2025, 01:23:47 PM
Author Topic: New Snorer 55 Engine From Brodak  (Read 22158 times)
Offline Dick Pacini
« on: April 09, 2012, 10:54:55 PM »
This just showed up recently on the Brodak site.  Not much info other than dimensions.  Ever hear of it?
http://brodak.com/engines/snorer-55-engine.html
AMA 62221
Offline John Sunderland
Re: New Snorer 55 Engine From Brodak
« Reply #1 on: April 10, 2012, 12:18:11 AM »
 Z@@ZZZ mw~ HB~>...surely they didnt call this motor a Snorer! n~
Offline Dick Pacini
« Reply #2 on: April 10, 2012, 12:47:09 AM »
AMA 62221
Offline Dan Bregar
  • Field Marshall
« Reply #3 on: April 10, 2012, 04:05:26 AM »
Looks like a MVVS to me.
AMA 33676
Offline peabody
« Reply #4 on: April 10, 2012, 04:47:20 AM »
I believe that the engine is made in South America....mayhaps Argentina?
Quite a bit of development to make it as user friendly as ST's....runs with a 2-4 and the barrel may be set for either side, or rear exhaust....
The two folks that I know that have been using them are quite impressed....
Have fun!
Yup....a Snorer!
Offline Bill Mohrbacher
« Reply #5 on: April 10, 2012, 06:13:49 AM »
http://www.snorerengines.com/motores.htm
It's from Argentina.  Their rep had one at Brodaks last year.
Offline jim ivey
« Reply #6 on: April 10, 2012, 06:16:17 AM »
are they gonna make a 1/2 A and call it a sneezer?   LL~  jim
Offline Andrew Tinsley
« Reply #7 on: April 10, 2012, 07:07:48 AM »
Did this go on Brodak's site on April 1st, by any chance?
Andrew.
BMFA Number 64862
« Reply #8 on: April 10, 2012, 07:40:56 AM »
Andrew.
My first thought
Offline Dick Pacini
« Reply #9 on: April 10, 2012, 08:40:17 AM »
Andrew.
I don't know when it was posted, but it is still there.
AMA 62221
« Reply #10 on: April 10, 2012, 10:00:32 AM »
It will stay there, it is real
« Reply #11 on: April 10, 2012, 10:34:49 AM »
Dan,
Good eye, looks like an MVVS to me also.
Venturi's for MVVS engines are available from the factory. We also know the case can be rotated 90 degrees and the engine can be used as a Rear Exhaust engine.
Nice compact pipes are available for the MVVS engine also. Another Factory item.
Interest?
Charles
« Reply #12 on: April 10, 2012, 11:13:53 AM »
Forget about venturi size. This is where you need to focus your effort with this motor. ;D
« Reply #13 on: April 10, 2012, 11:21:02 AM »
Let's see, your in the heat of competition. You walk over to the judge to get your score, and you find out it's 60 points lower than normal. You inquire as to what went wrong and, the judge tells you that "sorry,that last flight of yours was a snooze".
Seriously, we don't have many Marketing faux paus in sport, but this has got to be defintely one of them. Sure is pretty though!
Should have made it a .61.
« Reply #14 on: April 10, 2012, 12:31:04 PM »
Marketing faux or not,
That NIB, MVVS .40, is available!
Charles
Offline peabody
« Reply #15 on: April 10, 2012, 01:11:49 PM »
The Snorer is nothing like the MVVS....the Argentinian engine has a more traditional 2/4 run, with torque and a wide prop....they appear every bit as well made as European pieces....they hauled a sorta porky test bed around pretty well....
Have fun!
« Reply #16 on: April 10, 2012, 01:19:15 PM »
The Snorer is very very much like The MVVS, as it looks like a clone of the motor.
 I had these a year back and beyond and helped them with info on timing and I made True venturies and setup one for them to show how the induction system should be.
The difference is this has evolved into a lower timed stunt engine that has a larger displacement, and now works for stunt. Also when you set the direction of the exhaust think about it because once run, it needs to stay that way. They also run well on a CF pipe rear EX.
« Reply #17 on: April 10, 2012, 01:46:55 PM »
The difference is this has evolved into a lower timed stunt engine that has a larger displacement, and now works for stunt. Also when you set the direction of the exhaust think about it because once run, it needs to stay that way. They also run well on a CF pipe rear EX.Randy
Randy,
I may need a venturi for one. Muffler also!
I have two of these MVVS engines made in the Czech Republic. Both NIB.
Charles
« Reply #18 on: April 10, 2012, 02:13:57 PM »
Randy,
Charles
You should be able to get those quickly from Brodak, I have headers and CF pipes
« Reply #19 on: April 10, 2012, 02:34:44 PM »
You should be able to get those quickly from Brodak, I have headers and CF pipesRandy
Randy,
Aren't Brodak's venturies nylon or plastic?
Do you have a website?
Charles
« Reply #20 on: April 10, 2012, 03:15:38 PM »
Randy,
Charles
I do not know what his ventuires are made of, Mine are Delrin.
WWW.Aeroproduct.net
Offline Chris Wilson
« Reply #21 on: April 10, 2012, 04:21:12 PM »
I agree Randy, they are very MVVS!!
Part of the issue the old MVVS 49 (and indeed the entire 40/45/49 range) had was that it was in the upper ranges for weight vs capacity.
The Brodak site gives 12.52 ounces with the standard muffler (although the Snorer site states that this is the weight with NO muffler)  it not as problematical as the older range I suppose.  But have they kept MVVS's indestructible crankshafts, Akrobat timing and thick chrome on the liners?
Rear exhaust definitely is the way to go but you can revert to a different orientation after running. Doing this simply abbreviates the engine life by having to run it in twice but its obviously NOT recommended.
« Last Edit: April 10, 2012, 05:08:39 PM by Chris Wilson »
MAAA AUS 73427
MAAA AUS 73427
« Reply #23 on: April 10, 2012, 05:15:57 PM »
I know an MVVS Rep.
I could ask about that Snorer?
Charles
Walter Hicks
« Reply #24 on: April 10, 2012, 05:40:23 PM »
Peabody, since you have seen the engine in action. How large of a prop 13" and how heavy ,large was the plane? Is it equivalent to ST .60 , Does it
run in lower torque range 8000? I am looking for a less expensive Retro....
Online Paul Taylor
« Reply #25 on: April 10, 2012, 06:24:54 PM »
If I am going to throw that kind of money at a engine, I will spend a few more bucks and get a PA .40 UL from Randy.
« Reply #26 on: April 10, 2012, 07:57:20 PM »
Hi Paul,
             that is a puzzling thing to say when little is known about the new kid on the block don't you think?
And especially so when the design of both motors had help from Randy in the first place.
MAAA AUS 73427
Offline Norm Faith Jr.
« Reply #27 on: April 10, 2012, 08:01:33 PM »
Could "Snorer" be translated, from Portuguese, Brazilian (if a language) or what ever...into an English word?...Possibly?...Seriously?
Norm
Circlepilot   AMA9376
« Reply #28 on: April 10, 2012, 08:33:30 PM »
It seems this engine was kept a secret. Most of the time, we know about an engines development LONG before it ever hits the U.S. market. Gave us time to get excited about it.
Or was I just the last to know on this one?
« Reply #29 on: April 10, 2012, 08:36:35 PM »
Norm
Norm, they've GOT to change that name. ???
Imagine your at the flying field, and you have a hard time starting it. What are you going to tell people-it's sleeping? When you need parts, do you take it to a marriage counselor? When you want a new head machined for it, instead of a machine shop, do you take it to an E.N.T. specialist? How do you do a Rhinoplasty on a stunt motor?
« Reply #30 on: April 10, 2012, 08:44:27 PM »
Do you need to tell it to roll over? Do you need to set an alarm clock next to it set 5 minuets before your flight? Does it need to have a cup of coffee before it will run? LL~
I agree the name is totally lame. Snorer. Not good.
« Reply #31 on: April 10, 2012, 08:57:15 PM »
Prime it with amphetamines!!
Online Paul Taylor
« Reply #32 on: April 10, 2012, 09:12:02 PM »
Hi Paul,
U.S.Nationals - 1994,1997,1999,2000,2001,2003,2004, 2005,2009,2010,2011
U.S. Team Trials - 1995,1997,1999,2001,2003,2007,2009
Australian Nationals - 1997,1998,2009
Many Open Sr. and Jr. NATs wins
World's ,Advanced and Open National Championships
1994 NATs Open Winner Paul Walker PA 40 RE
1997 NATs Open Winner David Fitzgerald PA 51 RE
1999 NATs Open Winner David Fitzgerald PA 61 RE
2000 NATS Open Winner TED Fancher PA 61 RE
2001 NATs Open Winner David Fitzgerald PA 61 RE
2003 NATs winner David Fitzgerald PA 61
2004 WORLD GOLD Medal winner Bill Werwage PA61
2004 WORLD GOLD Medal winner Rob Gruber PA61
2004 NATs winner David Fitzgerald PA61
2004 Senior NATs winner Rob Gruber PA61
2004 Advanced NATs winner Orestes Hernandez PA61
2005 Sr Winner Rob Gruber PA61
2006 NATs Advance Mike McHenry PA65
2006 World's Siver Medal Winner Dave Fitzgerald PA75
2007 NATs Classic winner Jim Lynch PA 40
2008 NATs Jr. Winner Ryan Young PA 61 RE
2008 NATs Classic winner Keith Trostle PA-40 Merlin
2008 NATs Advanced winner Germanio(Alex)Becerril PA 61 RE
2008 WORLD F2B Champion David Fitzgerlald PA 75 Merlin
2009 U.S NATs Champion David Fitzgerald PA 75 Merlin
2009 U.S. Team winner Bill Werwage PA 61 RE
2010 U.S NATs Winner Bill Werwage PA 61 RE
2010 U.S. NATs Advanced Winner Eric Vigliuone PA 65 RE
2010 Jr. World Champion Winner Ryan Young PA 75 Merlin
2011 U.S. NATs Advaned Winner Ryan Young PA 75 Merlin
2011 U.S NATs Champion David Fitzgerald PA 75 Merlin
2011 Sr. U.S NATs Champion Ryan Young PA 75 Merlin
When the list gets this long on the snoozer engine I will give it a second thought. H^^
Offline Balsa Butcher
  • High Desert Flier
« Reply #33 on: April 10, 2012, 09:30:33 PM »
Sheesh, you're preaching to the choir here...many of us are huge PA fans and long time AeroProducts customers. The PA 40UL (yes, I have one) is not a competitor to this engine. This engine probably falls more into the "Gee, I wish I someone would build an engine that runs like a ST-60" type engine. I won't buy one as I have enough engines in this class (including an MVVS .49) but I hope it finds a market. With Brodak's excellent support and as Randy had a hand in its development, it should.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #34 on: April 11, 2012, 01:05:26 AM »
While i am glad to see a new engine on the market...the name did not sound like it was going to light any fires under anyone or was possibly a joke! looked one up tonight. Can anyone give me an all up weight for this engine?
Offline peabody
« Reply #35 on: April 11, 2012, 04:09:37 AM »
Okay then.....When I was watching the prototype it was well over a year ago (I tend to forget that I have been in Paradise for over 6 months), and saw an early rendition.......
It has evolved: Here's what the guy responded when I queried him.....
       The Snorer is a higher speed/ flatter pitch engine, but it will work fine with a muffler.  The maroon test bed plane weighed about 67-68 oz during the testing
Have fun!
Offline PerttiMe
« Reply #36 on: April 11, 2012, 06:57:30 AM »
Snorer?
As in "it could pull your plane around the pattern in its sleep"?
Online Paul Taylor
« Reply #37 on: April 11, 2012, 07:18:05 AM »
I'm sure if Brodak sells it and Randy was involved with the development of the engine it must be ok. But for my pocketbook I would not spend that kind of money on a unproven product. If you are telling me that this engine is not in the same class as a PA then I will not drop big bucks on a ST type motor.
And remember I still consider myself a newbie. Only been doing CLPA a few years.
 H^^
« Reply #38 on: April 11, 2012, 10:30:37 AM »
It has to go up against an Enya 60 PRO and an Evo 61,(and Stalkers, 51's are good). And, can it out hustle a Saito 62? They may be a day late and a dollar short on this one.
« Last Edit: April 11, 2012, 05:22:52 PM by proparc »
  • High Desert Flier
« Reply #39 on: April 11, 2012, 03:23:46 PM »
Actually it is the Evo 60 not 61 that is optimized for stunt. A very nice engine and $100 less than the   Z@@ZZZ (really should change the name). The Enya 61 Pros haven't been available for sometime now, hopefully we will see them again. Definitely agree with the statement about Stalker 51's, nice engine. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #40 on: April 11, 2012, 03:43:32 PM »
Hi Randy,
Since you worked on the development of this engine, somewhat, how do you compare it in run style and power to a PA .51, which seems to be the area this engine would be competing with.
« Reply #41 on: April 11, 2012, 04:42:51 PM »
Hi Randy,
Ah Bill, the voice of reason.
And you are right, the only person really qualified to judge this engine here would be Randy (but it could perhaps run into a conflict of interest supporting an outside product too heavily?)
I have my ears pricked up because of the possibility of spare parts from the Snorer range fitting the now discontinued MVVS 40 to 49 (or even the rear intake 51) glow models.
That and ....... well it just maybe a ripper of an engine in more categories than just stunt.
MAAA AUS 73427
« Reply #42 on: April 11, 2012, 05:22:50 PM »
I recall seeing a post or link to a website with the story on this engine from Argentina, right here on Stunt Hangar.
Perhaps a diligent use of the "search" function would turn it up for you? It was called the "Snorer" then, too.
They had an interesting way to "finance" the engines. IIRC, you paid like $3/week until it was paid for, then you got your engine. I didn't figure out how long it took to get one paid for. Argentines se habla espanol...dig it!  H^^ Steve
Walter Hicks
« Reply #43 on: April 11, 2012, 05:59:45 PM »
Maby it should be brought to our attention that it is very difficult to get a PA 65,75 ,now , they are $400 engines. Well worth it if you can get one.
Hopefully some one will give it another test and report on the new .55. Thank you Peabody for responding to my question regarding the .55.
Keep your eyes peeled as some people are converting to electric and are selling their PA. You get what you pay for.
« Reply #44 on: April 11, 2012, 06:11:43 PM »
I hear ya, Walter.  Of course the PAs for sale now are going for new prices.  Goes to show what the value actually is.
  • High Desert Flier
« Reply #45 on: April 11, 2012, 06:13:14 PM »
If it has a PA51 type run with an Aero Tiger price and MVVS quality it should be a hit regardless of the name.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline fred krueger
« Reply #46 on: April 11, 2012, 07:08:16 PM »
If the Snorer .55 runs anything like the MVVS 8cc Akrobat (which I think it is based on), it should be a good stunt engine.  See the YouTube link for the first full pattern of my MVVS powered plane.  Last year I experimented with prop loading and am currently using Thunder Tiger 12.5x5.5 props, which further improved the run.
Fred
« Reply #47 on: April 11, 2012, 07:18:21 PM »
Fred
That is my thinking too Fred, slightly more capacity in an engine built like a Russian tank and it's all good.
I note that the port shape in the liner is a bit different to the most recent trapezoid shape MVVS Akrobat ones though.
MAAA AUS 73427
Offline Geoff Goodworth
« Reply #48 on: April 11, 2012, 07:32:53 PM »
notice that people are still talking about the name Snorer.
I don't know, but maybe it means something very different in Spanish.
An example—in Oz, we have a Mitsubishi Pajero 4WD. In Europe, the same vehicle is a Shogun because in vernacular Spanish, Pajero (strawman) means wanker.  LL~ LL~ VD~
« Reply #49 on: April 12, 2012, 05:13:00 AM »
Here in Beaver Falls, we don't know what a wanker is.  Uh, maybe we don't want to know.
