  • June 23, 2025, 12:54:44 PM
Author Topic: ...suggestions...  (Read 1712 times)
Offline Bootlegger
...suggestions...
« on: September 21, 2013, 10:58:11 AM »
 I am looking for a Top Flight  Flight Streak foam wing, can anyone suggest where I might get one?
 Have a set of plans, but need foam wing only..
    Thanks a lot...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Ward Van Duzer
Re: ...suggestions...
« Reply #1 on: September 21, 2013, 12:52:39 PM »
Might try Bob Hunt...
Ward-O
Offline John Cralley
« Reply #2 on: September 21, 2013, 12:59:35 PM »
Check with Phil Cartier philcartier@earthlink.net proprietor of Core House  http://home.earthlink.net/~philcartier/
John Cralley
AMA 52183
Central Illinois
Mike Griffin
« Reply #3 on: September 21, 2013, 05:57:08 PM »
Johnny Duncan.. JDs Foam Wings in Vendors Corner
Offline Steve Thornton
« Reply #4 on: September 22, 2013, 01:44:21 PM »
I used a Gotcha foam wing with a Flight Streak/SkyRay 35 fuse & it few very well with an LA 25.  Bill Bishoff has a great way to cover these wings and they can really take a beating.
"Most of us won't make it out of this world alive."
Steve Thornton
« Reply #5 on: September 23, 2013, 01:34:19 PM »
Gotcha! Of course! Here's my Streaker..
Construction is duck soup. Cut your own 1/2" fuselage & 1/8" tailfeathers, Spray with rattle can. Cover wing and stab with colored Japanese tissue and brush on with water based Polyurethane. Trim was printed on my HP Officejet, cut out and "doped" under the japanese tissue. no need to bother cutting out each letter, just cut a rectangle with the text on it. The white paper won't show!
Ward
« Reply #6 on: September 23, 2013, 01:50:32 PM »
Ty,
Depends on whether you want to have fun, or just have fun!   #^
W.
Offline Bootlegger
« Reply #7 on: September 23, 2013, 02:25:31 PM »
  Yeah Ty, "Guy's just want to have fun"...Ward-o  I'm gonna call mine the "Streaker" as in Ray Stevens... y1 y1 y1
Gil Causey
AMA# 6964
Offline Bootlegger
« Reply #8 on: September 24, 2013, 08:17:00 AM »
  Ty, my wife tries to keep me on the straight and narrow also... LOL LOL
  Sat 28 Sept '13 Cathy and I are going to go to Lake Charles to Chanault A F B to a W W ll  flyin, supposed to have the only flying B-17 aircraft, I think that they call it Fi Fi, probably cost toooo much though, hope to get some pictures and post them here...
  Guy's thanks for all the ideas/advice... ~>
Gil Causey
AMA# 6964
Offline Bootlegger
« Reply #9 on: September 24, 2013, 08:20:52 AM »
  Steve T and Ward-O does the o/b wing fly high with the b/c mounted on top of the wing like that?
  If not what did you do to prevent it from happening?
  Again thanks for the help... H^^
Gil Causey
AMA# 6964
« Reply #10 on: September 25, 2013, 10:07:59 PM »
Yes mine did fly with the O/B just a little high, but it still flew very good.  I flew it straight into the ground and the wings came loose at the trailing edge. So I repaired it with no cosmetic thought and am anxious to see how it works.  I am using it to learn to fly inverted, so an O/B wing low doesn't worry me so much as it would most of you guys.
Steve Thornton
