  • June 16, 2024, 03:34:27 AM
Author Topic: New Plane  (Read 1779 times)
Offline stephen hollier
New Plane
« on: November 12, 2012, 10:19:50 AM »
This has been a somewhat of a long project and it's great to see it's coming to an end. I still need to install decals, and clear coat. The model is Dee Rices Oriental Plus powered by Ro-Jett .40 piped motor. The wing is fully composite.
Re: New Plane
« Reply #1 on: November 12, 2012, 04:30:05 PM »
What does that mean bro?
Re: New Plane
« Reply #2 on: November 12, 2012, 04:32:51 PM »
 It means the wing is fully composite. ;D
Re: New Plane
« Reply #3 on: November 12, 2012, 05:07:33 PM »
Bro bro, a foam wing with 1/64 plywood is a composite. Doug Moon made a wing out of fiberglass-that is a composite. Jose Modesto specializes in Carbon fiber wings-that is a composite. A fully balsa sheeted wing with carbon fiber veil all over-that is a composite.
So the question is, what composite is it?
Offline Zuriel Armstrong
Re: New Plane
« Reply #4 on: November 12, 2012, 08:11:08 PM »
Stephen,
The plane looks great.  I hope to see it in Dallas next summer.
Zuriel Armstrong
AMA 20932
Re: New Plane
« Reply #5 on: November 13, 2012, 06:34:47 PM »
Thanks guys for the comments and hopefully I'll have more flying time next year. In reference to the wing it's foam core that was sheeted with balsa then fiber glass. The foam was them removed. Dee Rice wrote an article about the process last year I believe. The wing is straight and strong.
Offline Geoff Goodworth
Re: New Plane
« Reply #6 on: November 13, 2012, 11:19:43 PM »
Actually, Dee's composite wing article was Flying Models, May 2009—the same issue as the Pathfinder LE.
Doesn't time fly when you are having fun #^ #^
Offline Allan Perret
  • Proverbs
Re: New Plane
« Reply #7 on: November 14, 2012, 08:48:09 AM »
How does that wing construction compare with the normal sheeted foam core construction relative to weight and time/effort involved ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Matt Colan
Re: New Plane
« Reply #8 on: November 14, 2012, 01:35:36 PM »
Looks great! I still have mine flying with a PA40UL, and is a pleasure to fly!
Re: New Plane
« Reply #9 on: November 16, 2012, 07:50:02 AM »
Thanks Matt.
2009 wow I have been a busy man for a few years.
Allan,
It's a little more time consuming, but I believe if constructed correctly it's lighter, and very easy to finish.
Offline Pat
Re: New Plane
« Reply #10 on: November 16, 2012, 09:44:26 AM »
How is the foam removed from the wing?
Pat
Offline Tom Niebuhr
Re: New Plane
« Reply #11 on: November 16, 2012, 09:53:49 AM »
Welcome back!
AMA 7544
Re: New Plane
« Reply #12 on: November 16, 2012, 10:09:49 AM »
Cut the foam out using hot wire. Similar to coring the wing.
Thanks Tom it has been awhile. Life and work has been keeping me real busy.
