  • July 03, 2025, 03:44:37 PM
Author Topic: New Loctite Glue "GO2"...have you tried it?  (Read 847 times)
Online Steve Helmick
« on: September 03, 2016, 06:51:18 PM »
Found it at the Ace hardware and thought I'd give it a try. It says it's a hybrid (Howard should like this) of Polyurethane and Polyoxysilane, whatever that is. It isn't "instant" by any stretch, but claims to be water and shock "resistant". The Spanish text says it is "Risistene a los Impactos", so I figure a model built with this stuff would be better than an Impact? Well, one could hope.
The good news for some is that it barely smells at all, and that smell is methanol. I'm going to try gluing two pieces of balsa together with it, like rib/spar. It looks like it would be excellent for gluing LE sheeting to ribs, because it has a 5 minute working time, 30 minute setting time, and 24 hr. cure. As usual, it says not to put it in your eyes or eat it.  LL~ Steve
Re: New Loctite Glue "GO2"...have you tried it?
« Reply #1 on: September 03, 2016, 07:31:45 PM »
    Hi Steve;
    i got a bottle of it from the local hardware store also. it looks the same as a different manufacturers glue sold at hobby shops to repair foam models, but is much less expensive. I've used it on some foam gliders and stuff just to try it out, and so far for that use it's worked pretty good. I don't think it will sand worth a damn, though, so you better not get any where it will have to be sanded.
« Reply #2 on: September 03, 2016, 09:24:58 PM »
Try it on some maple and see how well it penetrates.
