  • July 19, 2025, 02:17:27 PM
Author Topic: New kit  (Read 1940 times)
Offline Jack Mulinix
  • AMA 917877
New kit
« on: November 08, 2009, 11:17:55 PM »
Ordered a magician kit from Brodak on thusday and arrived on saturday. Those guy's are great! Was checking things out today, and saw the ribs have holes for a jig. I have a great planes wing jig, would that work ok, or just build as the inst. book says. any thoughts? thanks, Jack
Offline ray copeland
Re: New kit
« Reply #1 on: November 10, 2009, 08:35:27 AM »
Jack, i dug out my plans from the Brodak kit. I made no changes at all and built the wing on my table with no jig, i am sure you could use the jig. I put the leadouts exactly where the plans call and used a 1/2 oz. weight on the wingtip. Nothing adjustable, .25la for power , hayes 3 oz. tank on muffler pressure. Flies great right off the board. Great kit and plans. Good luck and post some pics.  Ray
Re: New kit
« Reply #2 on: November 10, 2009, 11:45:48 AM »
Same as mine it seems.  Built per the instructions/plans.  Brodak covering, tank and engine.  Flies great, but grandson now claims the plane.
Offline Don Curry AMA 267060
Re: New kit
« Reply #3 on: November 10, 2009, 12:32:01 PM »
I am finishing one right now. OS .25 LA 3 oz clunk tank on pressure and Ultracoat covering. Mine is balancing on the leading edge now, is that where you flew yours or should I add tail weight?
Don
Re: New kit
« Reply #4 on: November 10, 2009, 12:47:46 PM »
Don, is that with the engine,muffler and tank mounted? If it is that seems odd, mine balances about 1 3/4 inches back of the leading edge. I would say try it first then add tailweight if needed. I have tried to guess cg before by rubberbanding the motor in place and such and after i actually bolted everything on it was different.
Re: New kit
« Reply #5 on: November 10, 2009, 12:52:08 PM »
I just bolted the engine with muffler and tank on it this mourning. I still have to add the rear push rod and horn but other than that it is finished. I built is as per the plans with all the factory wood. Oh I did add a tail wheel instead of the skid.
Don
Offline Bill Adair
  • AMA 182626
Re: New kit
« Reply #6 on: November 10, 2009, 01:20:15 PM »
Don,
I'd love to see your new Magician. Are you going to bring it to Delta Park tomorrow?
Re: New kit
« Reply #7 on: November 10, 2009, 01:35:36 PM »
Bill: My wife has Verans day off so we will be doing something together and Friday I have a Dr. appointment so I wont be out until Monday at the soonest.I will bring it along even if it is not ready yet.
Don
  • AMA 917877
Re: New kit
« Reply #8 on: November 10, 2009, 10:11:20 PM »
Thanks for the input. I've been reading the instructions and looking at the plans. Was already thinking about adj. leadouts, weight box. All those things to make it the "best" it could be. You know, those flaps look like they could made coupled, but maybe just build it like it was designed.  os 25 w/ 3oz brodak tank. Will have to work at posting pictures. Thanks again, Jack
Re: New kit
« Reply #9 on: November 11, 2009, 09:17:25 AM »
I do not think the flaps will help that much.  In fact it will build quicker and have one less item to adjust.
