Are we still drilling a hole in our canopy to let the heat out? The real reason is I want to try and get rid of the staticy balsa dust that's clinging to the glass.
Kevin,
One must continually vacuum the model during the building stages. I blow mine out also.
The cockpit area should be sealed with a "floor" which will keep this balsa dust from getting under the canopy.
Is that canopy still available?
If so, a suggestion would be to trim this one to the bottom frame and replace it. Possibly just the center section?
Tending to the above mentioned before replacement.
Hey! I took a look at your airbrushed model. Really nice!
We could have a conversation about the canopy detail. No biggie.
You have hidden skills.
No longer hidden.
Charles
