  • June 16, 2025, 01:48:14 PM
Author Topic: NEW - Evolution 60NX  (Read 12638 times)
Offline Larrys4227
« on: November 04, 2010, 01:45:01 PM »
Coming in January .....
http://www.horizonhobby.com/Products/Default.aspx?ProdID=EVOE0605
I've had good luck with 3 Evo36's ... hope this is as well.
Looks like a great job with the needle valve too....
Larry
Re: NEW - Evolution 60NX
« Reply #1 on: November 04, 2010, 03:11:38 PM »
It looks like we are finally going to get our $150.00 sixty. The reviews on the 36 EVO was mixed at best. Let's see, if this is going to be any better.
Offline Allen Brickhaus
  • ACE
« Reply #2 on: November 04, 2010, 07:07:45 PM »
I have one to go in my T-Rex/The Shell Pusher P-47 project and review.
Allen
Dwayne
« Reply #3 on: November 04, 2010, 07:31:43 PM »
Or you can always buy a proven engine for $110.00 or the ringed version for $104.00
https://shop.mecoa.com/shopdisplayproducts.asp?id=29
Offline dennis lipsett
« Reply #4 on: November 04, 2010, 08:20:01 PM »
Regretably they are so proven that they aren't being used simply because of better engines  more up to the task.
I have them both and have run them and eventually I'll find a use for them. But in spite of the comments on the evolution 36 all of the ones that I've used have performed flawlessly.I'll buy the 60 and judge for myself how good it is. I like to prove to myself what a product can or cannot do.
Dennis
« Reply #5 on: November 04, 2010, 09:29:50 PM »
Allen
 Huh? What'cha up to Allen?
Dave Adamisin
« Reply #6 on: November 04, 2010, 10:20:53 PM »
Allen
Mine's gonna be a XP72....
« Reply #7 on: November 04, 2010, 11:26:22 PM »
 I've always thought the XP-72 would make a super cool model. Sounds like some interesting stuff guys...wait 'til you see the 'Rex that's currently under construction in Minnesota.  S?P VD~ ;D
Dave Adamisin
« Reply #8 on: November 05, 2010, 10:33:24 AM »
I can't wait to see it. It's so cool to have an arc that's good enough to kit bash. I've watched several (Joe Gilbert, Bob Branch) fly and they look very nice especially I like how they "sit" on the bottoms. I'm all fired up to get mine done....The wing has the Republic shape so any of the P35 through the xp72 are easily possible. I would like to do the xp44 with the cool NACA cowl and spinner.... I also am looking forward to other's being able to sample the big Evo...... Great time to be a stunt grunt...
« Reply #9 on: November 05, 2010, 10:53:32 AM »
 I wouldn't really call the kit quality of the ARC "good" (that's been beaten to death elsewhere), but is is very "bashable". y1
Dave Adamisin
« Reply #10 on: November 05, 2010, 11:49:02 AM »
Agreed, I was talking about the design.... The wood in my wing is VERY soft. One of the ribs has a knot in it.... Seriously.... Dennis had a good idea for stiffening the center section. I'm removing the planking and replacing it with single pieces that span the joint after I join the wing. I think the arc kit would be improved by that simple change. Supply the wood but leave the planking to the builder...... :!
  • ACE
« Reply #11 on: November 05, 2010, 12:27:39 PM »
Part of this winter's project is to put the Evo 61 in the T-Rex and P-47 it like everyone else.
Offline Andrew Borgogna
  • Andy
« Reply #12 on: November 07, 2010, 02:27:42 PM »
I would be very interested in knowing how the Evo .60 compares in power and "stunt run" with the LA .65 I am currently using in my Score.  It wins the weight war hands down the Evo has a total Weight: 13.4 - 15.9 oz, depending if you use a tongue or tube muffler.  The LA weights in a full  4oz. heavier(16.6 oz.) with a Mac tube muffler.  But I have had very good power and stunt runs with this motor.  It has proven to be very realiable.  Looking forward to hearing more about the Evo .60 engine after somebody puts it in the air.  A really good inexpensive 60-65 stunt engine is long over do for us non-experts.
Andy
Andrew B. Borgogna
« Reply #13 on: November 08, 2010, 10:25:06 AM »
The only thing that I'd like to know is if this engine is the 60 built on the 46 case.If so it would be a small package and has a lot of possibilities.
Dennis
Dave Adamisin
« Reply #14 on: November 08, 2010, 01:54:21 PM »
Dennis
Same case as 40, 46, and 52. Bolt pattern same as OS 46SF. Distance from front mounting hole to prop washer is slightly longer than OS. The plane I'm flying it in has flown with 46 SF. I'm using the same radial mount (fiberglass fuse) that held the SF. The SF had a 3/8" extension. The Evo has no extension but Big made me a 0.200" spacer plate to move the mount forward. Sooooo the front washer to front mounting hole difference between the SF and the Evo is about 0.175 with the Evo being longer.
« Last Edit: November 08, 2010, 06:20:41 PM by Dave Adamisin »
Dave Adamisin
« Reply #15 on: November 08, 2010, 04:30:02 PM »
A video....
« Reply #16 on: November 08, 2010, 04:51:52 PM »
The engine sounds good to me. Good transition. Guess I really do have to add it to the collection and use it.
Dennis
« Reply #17 on: November 08, 2010, 06:14:12 PM »
A video....
Secret test site!! You rolling straight up "Area 51" on us. You forgot the fuzzy round circle over the face of the flyer. Were all over the license plate number of the blue car driving in the parking lot. I hate to tell you this, but back at Langley, there were a bunch of guys in dark blue suits watching your flight on a VERY BIG screen.
« Reply #18 on: November 08, 2010, 06:28:30 PM »
A video....
  Still need to work out that inside/outside difference - it's breaking between a 2 and 4 in the insides, but hard 2 in the outsides.
Dave Adamisin
« Reply #19 on: November 08, 2010, 06:54:34 PM »
Agreed. I haven't had a lot of time to fine tune the installation. It's on the list. I was trying to make sure it held the setting (5.4 laps beginning to end in video)  and made the power to swing useful props.. The engine in the video is truly "out of the box" I didn't even take the backplate off. I ran 6 oz of fuel through it on the bench and bolted it in. Most people will do it that way so I wanted to duplicate that experience.
« Reply #20 on: November 08, 2010, 08:38:33 PM »
What props were you using at the "secret site". Motor sounds good by the way. Noticed you were using a fairly loud "FlowThru" brand muffler.
Dave Adamisin
« Reply #21 on: November 08, 2010, 08:53:12 PM »
The prop in the video is a 13.25x4.25 Bob McDonald undercambered carbon fiber. I had been using a 12x6 Zinger carved down to a reasonable thickness. I like the CF prop a lot..... Can't reveal the source of the CF in the prop though................
« Reply #22 on: November 08, 2010, 11:12:02 PM »
   LL~
This is a lot of fun.
Dave Adamisin
« Reply #23 on: November 09, 2010, 09:14:20 AM »
I updated the video with a location..... It's in the field next to the road where the balloon appears. The map won't let me put the balloon in the field..... Hmmmmmm maybe you're right about the "Langley" thing....
« Reply #24 on: November 09, 2010, 11:04:46 AM »
On a serious note,
Dave,thank you for trying to make decent, affordable products available to the stunt community. Shows what happens when experienced cats decide to return to the hobby. Business gets taken care of!!!
Thanks Mr. Typhoon H^^
Dave Adamisin
« Reply #25 on: November 09, 2010, 11:07:09 AM »
On a serious note,
Thanks. Please include Mr. Peter Bergstrum in your praise. He put his neck out there to get his company to respond to our needs. He likes u/c a lot....
« Reply #26 on: November 09, 2010, 01:49:40 PM »
I think I have a good idea where it came from  :-)   ;D
Dave Adamisin
« Reply #27 on: November 09, 2010, 02:30:13 PM »
I think I have a good idea where it came from  :-)   ;D.. H^^
Hmmmmmmm.... I'll bet you do H^^
Offline the original Steve Smith
  • Fly Stunt!
« Reply #28 on: November 09, 2010, 03:31:11 PM »
I wonder if that needle valve assembly will fit into the 36 so we can get rid of the remote needle valve?
AMA 2112
« Reply #29 on: November 09, 2010, 03:32:25 PM »
>>Please include Mr. Peter Bergstrum in your praise.<<
I flew with Pete when he lived in Spanaway. He was a pretty good stunt flier and his Competitor design was pretty slick.
« Reply #30 on: November 09, 2010, 04:31:34 PM »
The highlight of my summer before last was Pete flying my Crosswinds II after competition was over at the FCM!  He flew like he'd never laid the handle down for a few years!  His pattern sure looked better than the one I did with that ship - that's why I decided it was worth the refinishing!!
Will
Offline PeteBergstrom
« Reply #31 on: November 10, 2010, 10:08:10 AM »
Will and Randy,
Thanks for the kind words.  I was speaking with Allen Brickhaus the other day and shared with him that even to this day, with all the distractions I have involving the model airplane hobby that the first columns that I read in either Model Aviation or FLying Models are the stunt columns.  My heart has really never left my roots, no matter where my feet have taken me.
BTW - I'm finally going to finish a new SIG Super Chipmunk (my loving brother Dave, it a fit of fury, broke my only other one before I had a chance to fly it way back in my teenage years) our new **** engine, and I have a TP wing here that Bob Hunt built for me about 9 years ago now that has been getting lighter every year.  I plan toi try and get that attached to a fuselage of some sort for the upcoming season.
I hope you guys like the EVO 60NX CL ... Dave A put a ton of work into this for me as test dog and engineer - I just had to figure out how to get it done and in your hands.  I'm pretty proud of the efforts.
God Bless,
Pete
Offline Balsa Butcher
  • High Desert Flier
« Reply #32 on: November 10, 2010, 03:20:59 PM »
As far as this engine goes, I only have this to say: CLP** CLP** CLP** CLP**  HH%% CLP** 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #33 on: December 09, 2010, 02:44:39 PM »
Guys - I just got notification from our factory that the EVO 60NX CL's are on the way.  About 30 days and counting adn we'll be shipping them out.
BTW - I am working on a retrofit NVA similar to the one on the 60NX CL for the original 36CL.  It will be early spring before I have the NVA's and venturi's available.
Have a great day!
Pete
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #34 on: December 09, 2010, 03:51:00 PM »
Thanks Pete, great to see another option out there!
Offline Larrys4227
« Reply #35 on: December 10, 2010, 05:11:53 AM »
Have a great day!
Pete
Outstanding :-) ..... I'll be keeping my eye out for this!!  Thanks!!!
