  • July 18, 2025, 05:00:23 PM
Author Topic: New Cowl - handle with care ** Pics added.  (Read 1662 times)
« on: December 28, 2009, 10:21:44 AM »
I am almost done with a new cowl for my SIG (ARC) Akrobat. I will try and figure out if I saved any weight. (You guys know I build heavy) HB~>
I did manage to put a few cracks in it while working with it. No big deal. A little CA fixed it. ( yippee more weight!  HB~>)
Man that is a lot of work, but sure will look better then that big hunk of plastic cowl when I am done. y1
I will try and post some photos with weight savings later tonight.
« Last Edit: December 28, 2009, 05:02:06 PM by rootbeard »
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: New Cowl - handle with care
« Reply #1 on: December 28, 2009, 01:50:38 PM »
Ya.. Pictures....
« Reply #2 on: December 28, 2009, 05:01:23 PM »
Here are some photos.
I have a little filler on the cowl that I need to sand off.
I still have a little more meat to remove, but so far I have saved 1 oz in weight.
Still need to figure out were to put more vents in to let the heat out. n~
Offline Bob Reeves
Re: New Cowl - handle with care ** Pics added.
« Reply #3 on: December 28, 2009, 05:37:00 PM »
It looks fine...
« Reply #4 on: December 28, 2009, 06:33:29 PM »
Paul,
Cowls are something you just get a feel for. Takes practice. this one looks like a good start.
Offline kenneth cook
« Reply #5 on: December 28, 2009, 07:00:52 PM »
          Paul, have you settled on a way to hold it on? I sometimes glue small tabs of 1/32 ply on the inside of the fue protruding down into the cowl approx 1/4" to not only line it up but also to stop side to side movement while picking it up. In addition I have installed a crossmember down inside the fuse with a blind nut in it and I drill a hole through the cowl and use a long screw. Tp prevent the loss of screw I solder a washer on the inside so the screw never falls out. I then use a cut off of arrow shaft as a spacer so that I don't over tighten and crush the cowl. I first drill the through hole in the cowl then glue a piece of ply on the inside of the cowl. I then backdrill the hole this way the screw is seating on the ply and not on the balsa cowl. Looks great good luck. Ken Cook
Offline Zuriel Armstrong
« Reply #6 on: December 28, 2009, 08:01:20 PM »
Paul,
That looks good.  Like I said, next time attatch it first and then sand it to shape.  Work on the tank you want to install and we'll get her together soon.
Zuriel Armstrong
AMA 20932
Offline Bryan Higgins
« Reply #7 on: December 28, 2009, 08:46:08 PM »
Good Job Rootbeard H^^
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
« Reply #8 on: December 29, 2009, 09:01:01 AM »
The cowl is a good idea as I remember the plastic as being heavy.  But, looking at your cowl, you might think of closing down the opening a bit.  Like about half as much as you have now.  The out let needs to be at least twice as big as the inlet to create an augmenter effect.
« Reply #9 on: December 29, 2009, 11:21:57 AM »
Thanks guys!
Doc,
Noted, I will try and add a little weight back to the inlet. ;D
I am planning on cutting a few more vents some place to let the heat out.
Offline Harleyman
  • ACE
    • Circle Masters
« Reply #10 on: December 29, 2009, 12:09:00 PM »
Looooking goood! x:
Chris Sterner
AMA 1825
EAA 1429853
https://circlemasters.com
