General control line discussion => Open Forum => Topic started by: Zuriel Armstrong on May 05, 2006, 06:55:41 AM
I am getting ready to start on the Neptune and am curious regarding the motor mounts. The plans show 1/2"x1/2". That seems a bit large to me. Is this correct? They also appear to be cut to allow for a few degrees of engine offset? Any help or advice is appreciated.
Thanks ;)
Hi Z.
The extension will be on the way tomorrow. Remember, you will not need it for the OS 32F. From what I remember, the 32F and the Fox 35 w/extension fit in pretty much the same place except for NVA location.
As to the Maple Mounts, I will check my plans to night. !/2 X 3/8ths should be more than adequate. I undercut the mounts 1/8th where the tank will go leaving them 3/8ths square there. y1
Let me check tonight!
Bill <><
Z Are you building the classic Neptune from 1955? If you are your plans show the wrong size mts. I have seen the original plane many years ago and the largest they used were 1/2x3/8. Some people back then even used 3/8x 3/8 for a Fox .35
I have a set from Flying Models. I am not at home right now, but feel certain they are 1/2"x1/2". I would rather use the 1/2"x3/8" mounts but was afraid it would make the fuselage narrower than the original.
