  • July 22, 2025, 11:30:34 AM
Author Topic: needle valve assy. os46la  (Read 1281 times)
Offline scott bolton
« on: May 23, 2009, 05:26:24 PM »
 Hi all !!! Does anyone know if there is a direct needle & spray bar assy. that can be installed on the os46la to replace the RNV assy? I have not had great success with the remote needle valves. JMO!!! PLEASE HELP!!!! THANKS SCOTT
keep em tight !
Offline steve pagano
Re: needle valve assy. os46la
« Reply #1 on: May 23, 2009, 05:39:04 PM »
     These have worked well for me on the la 40
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCR49&P=ML
         -Steve P.
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #2 on: May 24, 2009, 03:43:42 PM »
The OS 40 FP nva is a direct replacement. I have done this several
times. The SuperTiger nva can also be used, but it requires just a
bit of drilling to get the ST nva barrel to fit. I just stuff some paper
towel in the intake of the motor and slowly drill it out, turn the motor
over and carefully remove the paper towel.
We are currently running an OS 46 LA with ST nva on an Imitation that
my son is flying and have had great success. Very steady engine runs.
Later, Steve
