  • June 15, 2025, 04:33:06 PM
Author Topic: Pushrod ends - Central Hobbies?  (Read 1592 times)
Online Paul Taylor
« on: May 03, 2025, 11:21:45 AM »
I’m out of these threaded pushrod ends. I use to get them from Tom and Central Hobbies. Any one have a source? Central Hobbies does seem to carry them any more.
Offline Colin McRae
  • Are we having fun yet??
Re: Pushrod ends - Central Hobbies?
« Reply #1 on: May 03, 2025, 12:02:04 PM »
I've just been using a simple 4-40 bolt and just cut off the head to form a threaded rod. Works well with 5 mm OD 3 mm ID CF tube.
Offline doug coursey
« Reply #2 on: May 03, 2025, 12:03:03 PM »
THEY HAVE THEM FOR THE 3/16 PUSHRODS IF YOU CAN USE A SLIGHTLY BIGGER PUSHROD
AMA 21449
Offline Steve Dwyer
« Reply #3 on: May 03, 2025, 12:11:34 PM »
I've used hardened 4-40 threaded rod. I have never seen a failure.
Offline Paul Wescott
« Reply #4 on: May 03, 2025, 06:42:24 PM »
The picture shows 3/16” pushrod “tubes”.  So if “They” have them… Who are “They”??
« Reply #5 on: May 03, 2025, 07:00:33 PM »
https://www.amazon.com/dp/B08JPSFKNZ?ref=ppx_yo2ov_dt_b_fed_asin_title
Throw away the metal ball links.  Takes 2 to make one pushrod.  Jam nut is a big plus.
« Reply #6 on: May 03, 2025, 10:29:30 PM »
   Check the R/C car parts section of the hobby shop and see if they have 4-40 turnbuckle or tie rods that short. Use the left handed thread end  f or gluing into the pushrod bore. The threads will help hold the epoxy like the grooves on the original units, maybe even better.
« Reply #7 on: May 04, 2025, 03:42:26 AM »
  CENTRAL HOBBIES
AMA 21449
