Mike, just for kicks and giggles, I measured my plans. The inboard flap measures 2 5/16" at the root and 1 1/8" at the tip. A note on the plans says both flaps are the same length. I measured 24 5/8".
There is a short stationary dummy flap at each tip that I didn't measure. Also the root of the flaps is swept away from the fuselage at the trailing edge. The root dim I gave was actually measuring along that angular edge.
The flaps are made from 1/4" balsa. Hope this helps. Some research on this forum turned up a post that said both the AMA plans and the UHP plans are about the same.
