Nylon, Glass Filled, Beech Wood, Maple, Carbon Fiber, Fiber Glass, Wide blade, Paddle blade, Scimitar Blade, Power point, Extra Wide etc. The list goes on and on. For some unbeknownst reason, I like wood props, I really don't know why, perhaps it's because back in the day the plastic variety were pretty crappy. Remember those white nylon Top Flite props? I learned to hate them, the vibrated, flexed, and had a nasty habit of throwing blades. Graupners were better if you could find them. Tornado props were OK if you could find them in the right sizes (Never could find the 10 inch 3 blade tractors) But you could always count on wood, especially the TF Super M.
I kind of considered props as consumables, as flying off natural surfaces always presented hazards like a hiden rock in the grass etc or sand and pebbles flying off of dirt surfaces. Then there was the inevitable nose in when the LG caught a weed etc. (Although you learned to mount your prop so when the engine quite the prop would stop in the horizontal position, I wonder how many still use that trick) Anywho Seems like there is a limited choice for wood props in the right size and I wonder how you would compare a prop of similar size and pitch between CF and wood. The weight of the spinning mass would be different so the loading is different. Is it pretty much near 1 for 1?
Also amongst the wood props, anyone have comments? Any good, better, worse?
You have XOAR PJA 12 X 4
Zinger Pro 12 X 4
Zinger std 12 X 4
In this size that is about it unless anyone knows of others.
I plan on getting at least 1 CF 12.25 X 4.3 or so props, but for everyday I still like wood, especially if debris is a factor (flying from Dirt or Sandy surfaces like is prevelent in Florida)
