  • July 18, 2025, 01:55:09 AM
Author Topic: Need help identifying cylinder liners  (Read 2396 times)
Offline Matt Neumann
« on: September 27, 2024, 11:48:07 AM »
I found 5 or 6 of these things.  The only thing I got was a note that says Thunder Tiger 36 liners.  I am wondering if these are the specially made ones that Randy Smith had made for the Thunder Tiger 36.  Can someone help identify if these are them?  I tried contacting Randy but nothing back yet.  I think they are aluminum which make me think that they are.  I am also wondering if they are just meant to replace the OEM one.  As in swap liners but keep the piston.
Matt Neumann
Re: Need help identifying cylinder liners
« Reply #1 on: September 27, 2024, 01:17:59 PM »
If those are ABN, which are stock TT .36 stuff, the base metal is brass, so the cylinder will be quite heavy. If they're light, they're aluminum. When brass cylinders are NICKLE plated, all surfaces are NICKLE plated, including OD and the ports, flange, etc. If they're chromed (either aluminum or brass), the base metal will be bare in the ports, on the OD and flange. If you determine that the plating is all over, you could file away a bit of nickle on the edge of the flange a bit and strike brass, without damaging the cylinder. I am not sure if there is a market for stock TT .36 cylinders without pistons.
My guess is that they're stock cylinders, because if they were chromed aluminum (Randy Aero) parts, the pistons would be fitted to each specific cylinder. The only other (slim) possibility I can think of is that they're really Brodak .40 cylinders, which don't (or didn't) come with matched pistons...which is absolutely not a good practice IMO.  D>K Steve
« Reply #2 on: September 27, 2024, 08:08:46 PM »
From the pics they are definitely brass but looks like no coating. Possibly a prototype cylinder that never got finished?
MM :)
