Quote from Chuck Matheny..."Delrin works OK but it leaves a fuzzy surface that I found to be a pain to clean up. I'm sure there is a trick to working this material that I am not privy to."
Sharp cutters are the deal with any sort of plastic, fairly low rpm and fairly high feed rate. REAL Delrin is very nice stuff, but I'm not a fan of the generic version, which is called "acetyl". A length of 5/8" Delrin rod is 10' and probably under $20...though I haven't bought any in years. They'll probably cut it in half for you for free, if it won't fit safely in your vehicle. Nylon and UHMW are MUCH WORSE!
If I turn the end of a Delrin rod just a gnat's butt too large to fit into the crankcase, I've found that it sands pretty nicely with 400 > 600 grit. My procedure is to face the end, center drill, double drill to finish size, turn the spud that goes into the crankcase/throttle boss, then do the other end. There, I start by bandsawing off with excess, face it off to a length I like, and use a single flute countersink to rough in the bellmouth. A little scraping with a #11 Xacto finishes it off. That part needs some experimenting with rpm, angle you hold the Xacto knife, pressure, and how sharp it is. Too much rpm is no bueno.
My lathe is a Grizzly 4" that they don't sell anymore. It's the same as a Hobo Freight 4" lathe, except cost more, it's green and has a longer bed. The length was why I got Grizzly. Micro Mark sells an even longer version, for even more money. From what I've read, they all come out of the same factory in PRC, and the factory has a basic menu of options for the importers. Length, brand name, color, and even tolerances are on the menu. Not a bad little unit for intake restrictors, plus spinner and head mods. The thing I don't like is that the dial on the cross feed is metric...about .040" per hashmark, ...that's one mm per side of your part. Big lathes sometimes were per side, and some refer to the diameter...which I prefer. But never fear, there aren't any manual lathes made in America anymore, so you just gotta deal with it.
I've reworked spinner backplates, counterbored spinner cones, modified spinner adapters, and cleaned up cylinder heads that had ugly 'scuff marks' on the top of the fins. Also have used it to modify a pendant lamp for the bathroom remodel, and make a new pivot pin for the neighbor widow's yardwaste bin lid...among the more spouse pleasing projects. I'm a retired machinist, from 1974 until 2010.
Planning your sequence of operations is KEY. Otherwise, you might find yourself with no good way to hold onto the part.
