I have ripped the gear out of both a kit Vector and an ARC Vector, so have some experience in the matter. Not to be a smart alec, but why is this happening? I hit a hidden sprinkler head in a grass field, and a hole in another field, both somewhat freak things not likely to recur. If your field is just so rough that this is likely to repeat, then go stronger. On the ARC Vector I added an external layer of heavy fiberglass around the LG mount area, up the sides of the fuse about a half inch, since by then its appearance no longer mattered. On the kit Vector with appearance points on the line I added ply doublers inside the fuselage to give more gluing surface, and made a longer (nose to tail direction) mount that would not be so prone to the "overturning" moment caused by the force coming up from the gear. That worked too.
