  • July 14, 2025, 10:42:19 AM
Author Topic: Nats Stunt Qualification Results  (Read 3233 times)
« on: July 19, 2012, 06:55:27 PM »
Here are official results from Event Director Dave Fitzgerald:
Re: Nats Stunt Qualification Results
« Reply #1 on: July 19, 2012, 07:00:15 PM »
Circle 3 : Dishing out the Big numbers !
Well done to all who qualified Top 20
« Reply #2 on: July 19, 2012, 07:08:42 PM »
Imagine it's your first time at the Nats, and you end up in circle 3.  :'(
Online john e. holliday
« Reply #3 on: July 19, 2012, 08:04:40 PM »
I see only 5 people did not qualify in Advanced.    D>K
« Reply #4 on: July 19, 2012, 08:13:24 PM »
The possibility that this can happen leads to support the argument that perhaps only a percentage of those entered should be sent on to a qualfying round rather than a set number.  However, there needs to be an upper limit of the number of qualifiers.  For current formats, 20 is probably the absolutely max number.  But it makes little sense to qualify 20 from even a field with as many as 30.  Something for the PAMPA Nats planners to ponder in the future, particularly if there is going to be an Expert category at the Nats.
« Reply #5 on: July 19, 2012, 08:23:23 PM »
SHOOT!!!  I probably missed the best chance I would ever have had to qualify!!! ;D
BIG Bear
RNMM/AMM
« Reply #6 on: July 19, 2012, 08:38:03 PM »
   Precisely my point in the other thread. This year, for instance, figure there would be 20 entrants in Expert and 22 in Open. If you still try to run 4 circles and take 50% of open, that means you would wind up taking 2.5 people from each circle. Or 3 from each, say. That makes the seeding hyper-critical. A better way to do it would be run Open on two circles and EXP/ADV on the other two, which at least reduces the "quantization" issues. Then you take the resulting 10-12 people and run Top 10 day to do a 50% cutdown. In open you could probably dispense with the Top 5 flyoff, and just have Top 10 day with the best 2 of 3 to determine the Open Championship. That will still be done before ADV/EXP Top 20 is done
   The alternative is you keep the very popular and well-established "Top 20" and then most people can skip qualifying, it will mean nothing.
   More likely, everyone will see the redundancy of running 3 divisions for 60 people total, and just get rid of Open since Expert will allow buy-and-flies and is thus more "inclusive". Mission Accomplished.
« Reply #7 on: July 19, 2012, 08:51:46 PM »
I like the current format.
Offline GonzoBonzo
  • GonzoBonzo
« Reply #8 on: July 19, 2012, 09:11:55 PM »
How does someone with a score in the 1000's qualify, and someone with a score in the 1100's don't?
Gonzo
« Reply #9 on: July 19, 2012, 09:30:56 PM »
   Because the absolute value of the score is not used. The 4 different groups are essentially 4 separate contests. Qualifying took the Top 5 from each group to get the Top 20. So if one circles judges are running high, and another running low, it doesn't matter as long as they get everyone in the right order in that group.
    In stunt *there is no correct absolute score*, period. One judge might give particular flight a score of 550, another might give the same flight a 450, and they could both be absolutely correct. All that they have to do is correctly score the better flights higher the worse flights less.
Offline GonzoBonzo
  • GonzoBonzo
« Reply #10 on: July 19, 2012, 09:45:12 PM »
Thanks Brett, that makes sense.
Gonzo
« Reply #11 on: July 19, 2012, 10:02:42 PM »
    It makes the determination of positions below 20 a little arguable, since there is no way to determine directly who flew best when they didn't fly against each other. The way it is done is to take the 2-day score (best on Wednesday and best on Thursday), and then divide it by the high score of the group they flew in. It's not bulletproof but it's probably as good as you can do with the information available. It probably tends to favor the guys in the groups with the lowest judge scoring variation, but that's impossible to distinguish between that, and merely that the competitors flew nearly the same.
   Note that any particular group flies for one set of judges on Wednesday, and the same group flies for a different set of judges on Thursday. The judges are assigned to a physical circle and stay there for both days.  The pilot groups fly two flights for one set of judges on Wednesday, and two flights for a different set of judges on Thursday. That's why you take add the best Wednesday score and the best Thursday score to get the total - one from each set of judges.
   This stuff has been hashed over for decades, anything that might look funny about it, I guarantee that there is a reason for it.
« Reply #12 on: July 19, 2012, 11:52:55 PM »
You can call it whatever you like... The current system spits out the correct results more times than not..
To get the best Top 20 fliers together for a showdown flying 2 rounds.. Best 5 scores go to the final.
Offline GonzoBonzo
  • GonzoBonzo
« Reply #13 on: July 20, 2012, 01:11:27 AM »
Thanks for the reply guys.  I was just curious.  Stuffs all new to me.   ???
Gonzo
Offline Allan Perret
  • Proverbs
« Reply #14 on: July 20, 2012, 05:29:37 AM »
How many qualifiers are flying electrics ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #15 on: July 20, 2012, 10:58:17 AM »
I know at least Walker and Hunt are on electrons from Circles 3/4. Rush at the 11 spot the same.
        Doug
« Reply #16 on: July 20, 2012, 11:07:59 AM »
You know that will never happen. If anything were to get dropped it would be Expert not Open.
Who's Mission????
Derek
« Reply #17 on: July 20, 2012, 12:12:42 PM »
  How do I know that would never happen? Because you, me, and Randy (and numerous others) think it's a bad idea? That's not going to stop it. One "excludes" people, the other does not. Drop Expert and all those people who were flying ARFs and $5000 RTFs will be left out with "obsolete" equipment. Drop Open, nothing much changes. Oops!
« Reply #18 on: July 21, 2012, 03:47:53 AM »
How many of the top 20 or even 30 do you think will quit building, buy an ARF, and fly Expert. My guess would be very few.
I was originally against Expert at the Nats, I told Randy that I just didn't think it would draw as many people as he thought and it was pretty much a waste of time. It was not until I started getting info from my District Rep. that was quite opposite of my beliefs that I gave it more thought. I now think it is a pretty good idea. There were many people (many that I had not expected) that said that they would love to fly Expert at the Nats. These are people that are Expert pilots on the local level but know that they would not be competitive at the top 10 to top 20 level. You know this is not just about us Brett, there are many other people that would enjoy coming to the Nats and competing in a skill class that is suited to their ability. All the people that I did talk to or was told about from my district rep. build their own airplanes. The Expert event is not just a place for ARFs to compete and that is not why Randy proposed it but it does give them a place to fly. The idea is to increase turnout at the Nats.
 Who knows, if someone wins Expert a time or two they may feel that they are ready for the big leagues and move up to Open. Like I said, it is not just about us it is about anyone who wants to compete at the finest flying facility in the world at the best contest in the world. Who are we to say no, just because we think it is silly?
Derek
