  • July 10, 2025, 09:43:47 AM
Author Topic: Shiny Fox 35  (Read 2858 times)
Offline Alan Hayes
Shiny Fox 35
« on: July 08, 2007, 06:14:45 PM »
I was looking through my engine drawer for a Fox 35 for a current project and ran across a polished Fox 35.  Trying to remember when this engine was released?
Alan
AMA 7064
"The measure of who we are is what we do with what we have" ~ Vince Lombardi
Re: Shiny Fox 35
« Reply #1 on: July 08, 2007, 07:33:26 PM »
I have 2 and they are both 1976 models.
Offline Tom Perry
Re: Shiny Fox 35
« Reply #2 on: July 08, 2007, 09:44:20 PM »
Alan,
If you upload a picture of it I could tell you.  I look them up in the Model Engine Encyclopedia.
Tight lines,
Tom Perry
 Norfolk, Virginia
Offline Bill Gruby
Re: Shiny Fox 35
« Reply #3 on: July 09, 2007, 02:49:32 AM »
   As Tom said, a picture would be a big help here. The first "Polished Case" .35 was a tumbled finish.It dates back to 1972. Does yours have muffler lugs? More info will be needed to date it properly.
    "Billy G"  j1
Bill Gruby
AMA 94433
MECA 5393-10
Offline Alan Hayes
Re: Shiny Fox 35
« Reply #4 on: July 09, 2007, 06:38:53 PM »
Taking a photo will not be a problem...me trying to load it to this forum may be a "real big" problem...but I will try and Bill the 35 does not have mounting lugs.
Alan
AMA 7064
Offline Bill Gruby
Re: Shiny Fox 35
« Reply #5 on: July 09, 2007, 07:30:58 PM »
Alan;
  Make sure when you post the pictures you put one in showing the exhaust side. It will help to identify your engine. The no muffler lugs tells me you may have a 15th Anniversary engine. The later ones were not Gold colored they had a "Bright" finish. That would date the engine to 1963. Don't get your hopes up, this is not written in stone I need to see the engine.
   "Billy G"
Bill Gruby
AMA 94433
MECA 5393-10
Offline Bill Mohrbacher
Re: Shiny Fox 35
« Reply #6 on: July 10, 2007, 06:08:01 AM »
Here is a 1972 shiney 35 stunt.  This guy has the vertical muffler mounts and "as cast" face on the exhaust.
Re: Shiny Fox 35
« Reply #7 on: July 10, 2007, 06:20:23 AM »
Here are a 1973 shiney stunt 35, has the vertical ears, but note how the exhaust is faced off.  A major problem with the first Fox mufflers (1972) was the as cast face on both the muffler and the exhaust; you could never get a snug fit and loosening of course occurred.  I used to draw file mine flat and had no problems.  Fox did this for us in 1973 and also changed his muffler to "envelope" the stack.
The other engine is a shiney 1975 stunt 35.  This year Duke added the horizontal "ears".  Now you could use these to hold on the muffler.  They were very weak and couldn't survive much vibration or a crash.  This was the last of the shiney 35s.
If you engine has no muffler mounting provisions at all, it is probably a 1963 Fox 15th anniversary special with the gold plating worn off or a SIG contest prize engine with the gold worn off.  The first of the 1963 engines had gold plated head bolts and rear cover bolts.
Re: Shiny Fox 35
« Reply #8 on: July 10, 2007, 06:25:51 AM »
Here's the gold plated 1963 stunt 35.  This is one I sold and the plating is mostly gone from the head, but you'll get the idea.
Offline Alan Hayes
Re: Shiny Fox 35
« Reply #9 on: July 10, 2007, 04:11:45 PM »
Here are a few pics of the 35 in question...
Alan
AMA 7064
Re: Shiny Fox 35
« Reply #10 on: July 10, 2007, 04:22:54 PM »
Alan, It's the Gold 1963.  The plating was very light and quickly disappeared with use or handling.  That is also the plug that came in those engines.
Offline Alan Hayes
Re: Shiny Fox 35
« Reply #11 on: July 10, 2007, 04:31:37 PM »
Thanks Bill for the info.   H^^
Alan
AMA 7064
Re: Shiny Fox 35
« Reply #12 on: July 13, 2007, 05:28:42 PM »
Hi Alan,
Lost internet Wednesday, so I couldn't get back to you!
I have a '63 "Gold" and so does Phil Green.  Both ours have pretty much lost the color off the crankcase from being run.......
Offline Alan Hayes
Re: Shiny Fox 35
« Reply #13 on: July 13, 2007, 06:38:03 PM »
Bill Little....I thought you were at the NATS since you had not been posting.
Thanks for the help anyway....lol
Alan
AMA 7064
Re: Shiny Fox 35
« Reply #14 on: July 14, 2007, 07:10:21 AM »
Alan
Hi Alan,
I was *supposed* to be at the NATS!
