  • July 18, 2025, 03:42:31 AM
Author Topic: PA Engine & Plane  (Read 2486 times)
Offline Gene O'Keefe
PA Engine & Plane
« on: May 26, 2010, 07:26:00 AM »
This mostly directed to Randy but also to all of you who fly Randy's products. Questions: if one was to graduate to a SV-11 and was only interested in a side exhaust, which runs better, the PA .61 or PA .65 ?   And because I have one, would a T&L Tigre .60 have guts to power ship ?  or should one go with Tim the tool man Taylor "more power" and just get the new PA .75 on a pipe ? ( but I'd rather have a side exhaust on a .61 or .65) Thanks for your replys.
 Geno
Gene O'Keefe
AMA 28386
Re: PA Engine & Plane
« Reply #1 on: May 26, 2010, 08:57:17 AM »
Well, all of the PA motors run great for me. I had a lot of success with the 61 and 40. I am very fond of the 65 though. Randy uses the 51 in his Katana and it is a very good motor. My personal favorites are the .51 and .65! ;D The .75 is a big powerhouse if that is what you are looking for.
All of mine were RE but the side exhaust work just as good!
« Reply #2 on: May 26, 2010, 09:23:03 AM »
   Any of those are sufficient for the airplane. The PAs are generally much higher quality and usability than any ST and far more durable/reliable, but the ST60 is more than adequate in terms of power, if it's running correctly.
I can't answer the 61 vs 65 question with any authority, haven't seen many PA side exhaust/muffler engines. I would guess that they run about the same and the 65 has a tiny bit more power. In either case you have far more than enough power. All the direct comparisons of the same engine, muffler vs, pipe, we have noticed that they run well either way, but you give up a fair bit of performance using the muffler. It's not really a power thing, it's a controllability issue. Bear in mind that these size airplanes are what we used to fly, 30 years ago, with ST46s. Getting any 60 to put out enough power is not the issue - it's how well you control the power. You can better take advantage of the larger much more "powerful" engines with  the controllability provided by tuned pipes. It works fine with a muffler, but we have tried it several times (using PA and RO-Jett rear-exhaust engines on mufflers) and it was clear that you give up a pretty fair bit of performance.
   And there is some pretty good evidence that the bigger, more grossly overkill you get with muffled engines, the harder they are to get to run just like you want - once again, you have to somehow control the overkill power, and with only a needle valve, it can get pretty touchy. I wouldn't expect much problem with an SV-11 and a 61/65 but we have seen more than a few examples of people putting gianter and gianter motors in the same sized airplanes (like a muffled 91 in a 700-square-inch airplane) on the theory that "I have a 91, why do I need a pipe?" and winding up having to make hair-trigger needle adjustments. If it changes by 1% of its capacity that's a huge change in the speed of the airplane. Windy had that problem (among others) at the NATs a few years ago. But it makes sense and corresponds to what we all knew back in the 70's and 80's when people were running only muffler engines - you need to match the airplane to the engine carefully or you either run out of power, or you can't control the engine and it either puts out way too much or way too little. PA61/SV-11, not a problem.
     The PA75 on a pipe (using David's setup) is the only engine that I would consider switching to right now, as I really like the run characteristics. It's not because of added power nearly as much as you can run it detuned to the point it runs as evenly as an electric motor. Of course it was semi-intentional that it runs a lot like mine so obviously I like it.
      If they are all a wash, cost and functionality-wise, it's really a no-brainer that the best system of those you have listed (and the one that will limit you less in the future) is the piped 75. It's the gold standard, literally. But any are sufficient to fly an SV-11 with good performance.
steven yampolsky
« Reply #3 on: May 26, 2010, 06:45:22 PM »
A local pilot flies PA65 SE on a muffler. It has this wonderful deep throat note, pulls the model with authority(If I remember, it's a 68oz, 700sq. in. Cardinal numbers, different look) and a has a wonderfull 4-2-4 break(if you want, you can still do 2-2-2). PA'a are famous for their piped 2-2 performance but the true "diamond in the rough" are PA side exhaust series! We are talking about all traits that make PA's so popular: power, easy to setup, consistent performance. Did I mention lot's of power? Yep, side exhaust PAs are just as strong as their RE brethren.
As to .61 vs .65 version, you can't really go wrong with either one. To help you choose, take into consideration your building skills. If you tend to build on the heavy side, err on more displacement side. If you build at design weights, .61 should be more than enough power-wise.
Offline peabody
« Reply #4 on: May 26, 2010, 08:13:13 PM »
I have a SV that I got from an Expert flier that has 1000 flights on it.....it is powered by an ST .51 square head running a wet 2.
The SV is a great flier, and any of the engines mentioned will fly it.
Have fun
« Reply #5 on: May 26, 2010, 08:46:26 PM »
Jack Pitcher (formerly of Gresham, OR, now in Colorado) has been flying his CENTENNIAL with a PA .65 side exhaust and a Randy Aero tube muffler. It sounds great and seems very powerful, giving a slow-motion look to the pattern, 100% under control. I am sure you could get the setup from Jack or Randy, and that you'd be very happy with the .65.  H^^ Steve
