  • July 14, 2025, 10:01:09 AM
Author Topic: Mystery Plane  (Read 5813 times)
Offline David M Johnson
Mystery Plane
« on: December 05, 2009, 03:37:16 PM »
At our sport speed event one of our club members had this airplane and was wondering what it was.  The ribs have stenciled numbers so I do believe it is a kitted plane just not what it is.  Thanks again David
We're havin some fun now!!
Re: Mystery Plane
« Reply #1 on: December 05, 2009, 04:15:43 PM »
 I'd say it's a scratchbuilt job that someone just put together using a rib set from some other kit. If I was betting on it, I'd say it's a Ringmaster wing.
Offline builditright
  • So happy to be alive!
Re: Mystery Plane
« Reply #2 on: December 05, 2009, 04:53:05 PM »
actually if you look close and follow the top fuselage line it looks like it is the ringmaster (S1A) with balsa scabbed onto it. tail is altered and may have been thickened up too.
Thank you and God Bless
Walter
aka/ builditright
Re: Mystery Plane
« Reply #3 on: December 05, 2009, 05:45:27 PM »
Chopped ringmaster no doubt. H^^
Offline Richard Grogan
Re: Mystery Plane
« Reply #4 on: December 05, 2009, 06:22:09 PM »
S1a wing with home-brew fuse/tailfeathers.
On another note, has anyone ever seen a S1 fuse/tailfeathers with a flite streak wing? Possible future project!
Long Live the CL Crowd!
                  AMA 85745
Offline Larry Fulwider
Re: Mystery Plane
« Reply #5 on: December 05, 2009, 08:01:47 PM »
. . .   If I was betting on it, I'd say it's a Ringmaster wing.
The S-1 has a spar and a "baseball bat" LE. This looks like a D-Tube and definitely no spar.
     Larry Fulwider
Offline pat king
    • PDK LLC
Re: Mystery Plane
« Reply #6 on: December 05, 2009, 08:43:08 PM »
That sure looks like an S1A Ringmaster wing.
Pat
Pat King
Monee, IL
AMA 168941
Re: Mystery Plane
« Reply #7 on: December 05, 2009, 08:45:58 PM »
I dont think it is a ringmaster, like was mentioned, the mid wing spar is not there, though the square holes could be where it would go,, but I doubt it because to make the leading edge a C tube, ( or D tube) would require shaving down the ribs,, a painstaking task,, at best
Online afml
Re: Mystery Plane
« Reply #8 on: December 05, 2009, 09:48:05 PM »
Note the use of Ambroid cement and a BUILT-UP trailing edge instead of a solid notched piece??
Firecat wing??
Don't know fer sure. HB~>
TY!  Where are you when we need you?!?!?? LL~ LL~
Building airplanes I guess! #^
"Tight Lines!"
Wes
Wes Eakin
Offline skyshark58
  • skyshark58
Re: Mystery Plane
« Reply #9 on: December 05, 2009, 10:15:58 PM »
I"ll vote Jim Walker "FIRECAT". Wing and horz/elv look like one.The stamped numbers on the ribs arn't Sterling or Goldburg.
mike potter
Re: Mystery Plane
« Reply #10 on: December 05, 2009, 11:54:02 PM »
The more I look at it, the more I see it isn't a S1A Ringmaster wing. Those rectangular holes in the ribs aren't right. The Ringmaster has round or oval holes,if I'm not mistakened.And the trailing edge is sheeted, like a RSM S1! Those holes look big enough to be  spar holes! Maybe more angles with the camera would help. I have no idea. Good luck
                  AMA 85745
Offline dennis lipsett
Re: Mystery Plane
« Reply #11 on: December 06, 2009, 04:29:15 AM »
It could be an Estes  Stunting Jr Ringmaster wing. They had a c type wing with 2 spars.
Dennis
Offline Will Davis
Re: Mystery Plane
« Reply #12 on: December 06, 2009, 08:38:38 AM »
Ringmaster S-1A wing and fuselage with wood added to top of fuselage, ringmaster doublers for sure .. Can't figure out the square  holes in the wing .. maybe someone cut for some type of jig or possable a later  (after Sterling or between S1 and S1 A version  ).. probably a put together from other crashed planes model
Just my guess
Will
Will Davis
"Carolina Gang"
Offline George
  • Love people, Use things.
Re: Mystery Plane
« Reply #13 on: December 06, 2009, 08:53:10 AM »
My vote goes for the Ringmaster Jr. wing with modifications. Modified fuselage and tail section are evident, but it looks as if the wing has been modified to include a wider center section (as I did mine) by adding the part between the wings that is normally removed. The later Estes kit had apparently been intended for some type of competition because the box calls for anything up to a .25 and the box shows a Fox (.19 or .25) schnuerle. I have an Enya .09 on mine.
Looking at the pics, I think it is too small to be a S1-A, although the construction is similar.
Of course, like everyone else, this is just a guess.  H^^
George
George Bain
AMA 23454
Offline Ward Van Duzer
Re: Mystery Plane
« Reply #14 on: December 06, 2009, 08:54:01 AM »
Nope! No FireCat here. All 3 F'Cats had solid trailing edges and "V" shaped Leading edges that were to be rounded off.
I have all the plans!
W.
Offline Zuriel Armstrong
Re: Mystery Plane
« Reply #15 on: December 06, 2009, 01:27:17 PM »
Maybe a Combat Cat wing and Ringmaster fuse?  The doublers look like the Ringmaster.
Zuriel Armstrong
AMA 20932
Online john e. holliday
Re: Mystery Plane
« Reply #16 on: December 07, 2009, 12:00:52 PM »
I agree to the S-1A wing put in what someone called a fuselage.  There is no central spar as it is a C tube type leading edge.  I had one of the few in this area an flew the heck out of it.  I think the sqaure holes were cut into the ribs by who ever built it.  It is definately not a Combat Cat either as that was my choice of combat wing in the early days of my combat flying.  Also far from being a Fire Cat wing also.  I still have my Fire Cat.
Re: Mystery Plane
« Reply #17 on: December 07, 2009, 05:53:03 PM »
. . .  I think the sqaure holes were cut into the ribs by who ever built it.  . . .
Nope. Those are die-cut holes for leadouts. You can see the rear leadout in one pic  ;)
Definitely a sparless C-Tube wing design, with sheeted TE, from a kit.
  Larry Fulwider
Offline Chucky
Re: Mystery Plane
« Reply #18 on: December 07, 2009, 06:05:30 PM »
Lookslike a Dick Sarpolus Pretender.  The forward canopy and short square fin give it away.  See link.  Blackhawk used to make a kit, I believe.
http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=250627&
Chuck Winget
Offline Chucky
Re: Mystery Plane
« Reply #19 on: December 07, 2009, 06:18:40 PM »
Further research indicates it's NOT a Pretender either -- wrong wing.
Chuck Winget
Offline W.D. Roland
Re: Mystery Plane
« Reply #20 on: December 08, 2009, 02:30:24 AM »
Guarantee 100% it is not a Ringmaster S1a wing.
It is not Combat Cat wing either.
Having built most all the kits from Top Flight, Goldberg ,Sterling my best guess is it is not from one of these MFGs.
I do like the wing on it though.
David Roland
51336
Re: Mystery Plane
« Reply #21 on: December 08, 2009, 04:50:50 PM »
Just curious, but where  is this thing located?  Australia?.  It may be a British kit. D>K
Does it get that cold down-under? LL~
Offline dale gleason
Re: Mystery Plane
« Reply #22 on: December 08, 2009, 10:55:00 PM »
The "Firecat" by Jim Walker had no spar at all. It was a good idea to add a couple,  dg
