  • June 24, 2025, 02:46:42 AM
Author Topic: engine spacing  (Read 2453 times)
Offline builditright
  • So happy to be alive!
engine spacing
« on: September 24, 2010, 04:35:02 PM »
Can anyone tell me
what's the engine spacing (length and width)
for a rail mounted half-A engine?
 /DV
Thank you and God Bless
Walter
aka/ builditright
Re: engine spacing
« Reply #1 on: September 24, 2010, 05:03:29 PM »
Walter,
You mean like for a TD or something? Distance between rails and length?
Re: engine spacing
« Reply #2 on: September 24, 2010, 05:20:11 PM »
If you do, it's gonna vary -- my Norvel 049 is 0.71 wide at the crankcase, while my McCoy 049 is 0.65.  I don't know what a Cox TD is, nor a Brodak 049.
Re: engine spacing
« Reply #3 on: September 24, 2010, 10:31:05 PM »
Can anyone tell me
 /DV
Hi Walter,
They all have different mounting dimensions.  The same brand usually are teh same, but Norvel to Cox (Medallion/TD) to Brodak do not match.
The Brodak .049 and .061 are in production along with the Wasps (.061 and .074), the
others are not in production, AFAIK.
The old McCoy/Testors/Wen Macs were different, too, as were the OK 1/2As.
Pick one, and we can give the spacing. y1
Mongo
Offline Wayne J. Buran
Re: engine spacing Brodak .049
« Reply #4 on: September 25, 2010, 04:07:58 AM »
Crankcase is 18MM wide, the screw hole spacing is 24MM from side to side is 24, and the hole spacing is 10MM is ctr to ctr.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
Re: engine spacing
« Reply #5 on: September 25, 2010, 07:10:50 PM »
Okay here's what I need it for...
I have been given the approval to make Dick Sarpolus's designs, both R/C and C/L.
that said, I have started to put into AutoCAD a Half A profile Edge and I need the
measurements for the engine cutout.
See below.
Walter
aka/ builditright
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: engine spacing
« Reply #6 on: September 25, 2010, 08:36:15 PM »
Set the mm beams 3/4" apart (inside edge to inside edge).  You may have to shave the inside corners off to clear the crankcase, but it makes for a snug fit, and the bolt holes will be nearer the center of the beams.
Don't even think about prefabbing the holes themselves, there's just too much variation.
--Ray
AMA902472
Re: engine spacing
« Reply #7 on: September 25, 2010, 08:49:02 PM »
If I measured my Norvel correctly (which is questionable, I didn't take it out of the plane) then you're saying that a .71 case in a .75 space is "snug".  I'd say that's "loose".
My preference would be a kit that is cut out to put the bearers as close together as the narrowest engine you're likely to see, with instructions or kit features to widen them as necessary.  A close second would be to make them as wide as the widest reasonable engine, with a supply of shims to narrow them up.
But I'm kind of a finicky builder.
Offline George
  • Love people, Use things.
Re: engine spacing
« Reply #8 on: September 25, 2010, 09:08:03 PM »
Walter,
I would go for .7 inches, or whatever Dick used for the Tee Dee. The TD and the Norvel  (and probably the Wasp) have the same mounting hole positions, although the crankcase on the Norvel is just a tad wider than the TD. Those should be, by far, the most used engines for that model.
I would make the hardwood mounts wide enough to accommodate a little whittling to fit other engines.
George
George Bain
AMA 23454
Re: engine spacing
« Reply #9 on: September 25, 2010, 10:06:00 PM »
like this...
.70 spacing
3/8"x1/4" mounts
with a norvel in it
Walter
aka/ builditright
Re: engine spacing
« Reply #10 on: September 26, 2010, 07:16:36 AM »
Do like Carl Goldberg used to do, if he doesn't have a patent.  The slots for the engine mounts were wider than needed and you shimmed them to fit the engine of choice.  At least that is what I had on all three of the profile stunters of his. H^^
    • Minnesotamodeler
Re: engine spacing
« Reply #11 on: September 26, 2010, 07:45:12 AM »
You guys are right, I've been building off templates so long I forgot the measurements.  Checked one; I'm using 11/16" gap (.6875) which requires a little whittling of the inside edges.  Sorry for the misleading info.
--Ray
AMA902472
Offline Steve Scott
Re: engine spacing
« Reply #12 on: September 26, 2010, 04:07:59 PM »
I've always found it's easier to cut a stick shorter than cut it longer.
Make the cutout narrower than required and we can trim it to get a good fit.
Those Brodak composite profile "C" mounts?  They are always too narrow.  I clamp mine in a 4" vise and file (a rasp works great to remove a lot of material; a metal file works great to hone it to the final size) to open it up one side at a time.   I file it flush with the vise jaws.  Works really well...
