When I started out to make a totally new design AND make the design expressly for mass production, I had no idea how really tough it would be. Not to mention heartbreaking. One thing to remember in engineering projects, prototypes are for testing, not for showing off. Anyway, TRX 1 has been finished, flown, and retired. Now I am working on TR2.
The only real issues with the project so far are not based on the aerodynamic package, but instead have been construction and weight related. The Devil's in the details!! The first proto was simply far too heavy and the engine was too low. Any weight under 70 oz should fly great, over that...cough cough ahem. TR1 was about.... a lot more than that. Right now TR2 looks to be heading for about 62-64 oz with a paint finish with about 1.5 oz of tip weight. With the film finish, I think 56-60 would be closer to the norm without a pipe or big 4 stroke.
One interesting wrinkle. I wanted to try aluminum mounts. On a hunch I bought the OS Max aluminum mounts for the OS 52 FS from Tower. I knew I had switch PA's and RO Jetts with the OS Max 52 using the same mounting holes. Well, the OS mounts come pre-drilled and fit my PA 65 (with slightly oversized mounting holes) perfectly!!! Even the distance to the nose is perfect. The OS mounts are like all OS metal parts, very nice (like a jewel). For me, this is drop in.
