  • July 11, 2025, 08:47:26 PM
Author Topic: My P40 Maiden Flight  (Read 15307 times)
Offline Kafin Noe’man
« on: May 04, 2024, 08:16:42 AM »
Finally, my P40 has made its maiden flight.
Good flying airplane in general (very authoritative and stable in the air), though I still have to find the perfect prop and engine setup combination.
I currently put
OS LA-46
TT 11x4.5
Nitro 5%
60ft lines eyelet to eyelet
I did experimenting several launch RPM:
9500ish — gives me 5.6 sec lap times with just okay power
9750ish — gives me 5.0 sec lap times with good power, but sags at some point.
I’m still not happy with how the engine runs as it shows very dark/black fuel residue which can also be an indicator that the engine is on too lean side.
I’m going to try other prop sizes.
Will try putting APC 11.5x4 first, then 11x4, and lastly 11x5.
What do you guys think? Which prop size should be the first try?
Re: My P40 Maiden Flight
« Reply #1 on: May 04, 2024, 08:58:24 AM »
I ran an OS46LA on my profiles a few years back.  Slightly larger plane (620 Squares,58oz) MAS 11x6 at 9500 on 62' lines. I ran a fast 4 on 5 or 10% and had no power problems.  I am not familiar with your weather so you should rely on others for the fuel mix.  My experience with the LA46 is that it likes to be loaded.  I had very bad results running higher RPM lower pitch props.  The 11x5 should work but you might try the 11x6.  Pix is just to show you the size plane it is pulling next to a much smaller Nobler ARF.
« Reply #2 on: May 04, 2024, 10:19:44 AM »
I’d go with the APC 11-4 or 11-5 if you need more speed.  However the black residue is corrosion in the engine and says it’s about done.  Common in humid climates or near indoor humidifiers very long.  Ask me how I know….
Online EricV
« Reply #3 on: May 04, 2024, 11:23:10 AM »
Dave is probably right, but being the eternal optimist, you might check that big muffler and make sure you have the interface smooth and flat and there isn't a vibration/ loose rub going there that is making the black metal.
EricV
Offline Colin McRae
  • Are we having fun yet??
« Reply #4 on: May 04, 2024, 12:00:59 PM »
Kafin
I run an Evolution 36 on my P40 ARF w/ MAS 11-4 prop. The EVO 36 has roughly the same power as an OS 46LA. And I am running 60' 018 lines. And I typically run 10% nitro and 20% oil on my more modern engines. My ground rpm is around 11,500 on the MAS 11-4. (BTW, some have said the MAS props generally perform as if they had less pitch. In other words, a MAS 11-4 probably performs more like a typical 11-3 as an example. Not sure but maybe they flex under load relaxing the static pitch.)
I can't speak to the black oily residue or the health of your particular 46LA engine. But my description below assumes a 'good running' LA engine.
You also have an 'after-market' venturi and NVA. That setup, not being OS stock, might be contributing to some engine run issues, but not sure. If the venturi is too large for instance, that could contribute to an engine run or performance issue.
When I have a new model/engine combination, I don't start with a particular ground rpm. It is actually the last thing I just document for reference after I get the engine/model setup running how I like.
I have run all the various size OS LA engines. They all have worked great for me totally stock. I use the stock tube muffler with the internal baffle installed. And I run muffler pressure on the LA's.
I always start with a 4-pitch prop on a new model, usually an APC sport prop. And I start with a prop diameter that suits the model size. In the case of the Brodak P40 ARF with 46LA, I would start with a 11-4.
The LA engines like to run fast for best performance. I personally don't set the needle to try to get a 4-2-4 break on the LA's. Just like the OS owner's manual says, I find peak rpm on the ground (i.e.: if I go any leaner the speed starts to fall off). Then, just as the owner's manual says, I open (richen) maybe 30 deg or so just when I notice the rpm to just start to decrease a little. OS calls this the 'optimum' engine speed. Then I fly the model.
If the model is flying too fast for my liking, I might try a 3-pitch prop. If too slow, a 5-pitch, etc. Totally trial and error. I even try different manufacturers props. MAS, BYO, etc. until I find the prop that flies the model best. In the case of my P40, I ended up liking the MAS 11-4 best.
Then to adjust lap speed, I might play with the line length. (I might also tweak the rpm just a bit, but not more than maybe 200 rpm either way. I still like a relatively fast 2-cycle on the LA's where they seem to perform best based on my experience.
When trying different props, I still set the needle again to 30 deg or so off of peak rpm on the LA's. The ground rpm will be different for each prop I try.
Once I finalize the engine/prop combination I finally document the ground rpm so next time I fly I know were to set the needle.
There are always some tweaks on the above, but this is the basic procedure I have used on any new model/engine combination. It has worked well for me to date.
Also BTW, I run a 46LA on my heavy Vector 40 (62 oz). After numerous prop tries, I ended up with a wood BYO 12-3 which seems to pull the model best. The BYO design is a very wide prop. And I fly the model on 64' lines. My ground rpm is right at 10,000.
« Last Edit: May 07, 2024, 05:51:17 PM by Colin McRae »
« Reply #5 on: May 04, 2024, 02:34:27 PM »
You are lucky to have a TT 11x4.5. That was the prop for a LA 46 and should work fine on the P40.
You could launch around 9800 just as it starts to crackle.
If you have not run the engine with wrong mix or screaming lean you might just have some lose screws on the motor or muffler. If you did scorch the motor don’t discard it. Just look for a P&L drop it in a go.
Check all your screws first.
Online Brent Williams
« Reply #6 on: May 04, 2024, 09:26:56 PM »
I ran that Thunder Tiger 11x4.5 on my LA46 and it was a magical prop!  We launched it around 10,200 RPM and it would settle into a fast 4 cycle in the air.  Very consistent and reliable setup.  Regular OS needle valve with a bit of fuel tubing to seal the needle, and the smaller OS .257/6.5mm venturi.  10/11-11 fuel. 63ft lines total (c-c).  Lap times were around 5.25 if I recall correctly.  Loved that setup.  Burned up many gallons of fuel with that combo.
« Last Edit: May 05, 2024, 03:02:14 PM by Brent Williams »
Offline kevin king
« Reply #7 on: May 04, 2024, 09:54:12 PM »
Kafin, What kind of fuel are you running? How much castor oil is in your fuel? Some off the shelf fuels only contain 16%. Maybe that's the cause of your black exhaust residue.
Offline Peter in Fairfax, VA
« Reply #8 on: May 05, 2024, 05:58:16 AM »
Kafin,
How broken in is the engine?
thanks,
Peter
Offline Steve Dwyer
« Reply #9 on: May 05, 2024, 08:06:31 AM »
Dave,
I have often wondered about the black residue but never considered internal corrosion the cause.  I run OS FPs and LAs and don't see the black residue but I do see it with my OS Max-S 35s. I have used both 5% nitro with 28% castor and 10% nitro with a 23% 50/50 synthetic/castor blend and see the darkening exhaust using each fuel. I also see it at different NVA settings, different plugs and with low and higher pitch props. Having inspected these Max -S engines, none have "internal corrosion". They show minimal wear and appear to have good compression. I wonder if the blackened residue is a characteristic of the style engine porting and "cooking of the oil" or blow by once the engine heats up?  I'm very curious if someone here can recall using new engines back in the day and if they all created this condition early on. This would be key and might define the cause being engine wear even thou not visible but beyond acceptable tolerances. Perhaps a new sleave and piston would help resolve the mystery, if I could find these items.
Offline Colin McRae
« Reply #10 on: May 05, 2024, 08:34:18 AM »
Dave,
I see some of the same black residue on my OS Max-s 30. But not on any of my OS LA's
I have been running 10% nitro / 28% (50/50) oil on the Max-s so the engine should be getting plenty of lube. Engine continues to be strong w/ good compression. BTW, I'm going to lower the oil to 25% per the OS owner's manual.
I also would be interested in what others say is the primary reason for the dark oily residue.
« Reply #11 on: May 05, 2024, 09:20:04 AM »
Dave,
Some engines are more prone to it than others which I believe is the metallurgy involved.  Fox engines can be especially bad about it,  and McCoys seem impervious.  OS's and Enya fall somewhere in between.   The engine I used this year at VSC,  an OS 35S began purging black just before I made the trip.  I have other engines but had no time or weather to work it out so I just hoped it would get me through.  Well it did get me through Day 1 but got hard to start and hard to set on Day 2.  I have pulled it now and have another 35S in the plane.  I think the corrosion begins either on the shaft or bronze shaft bushing and in the piston wrist pin holes mostly and the residue is gritty.  This then becomes a slurry of grit that wrecks the engine very quickly.  It wouldn't take very much.    I have had a few cases where an engine has cleared itself of the black crud in a few runs then kept going without any real problems but usually it works the other way.  In no way do I believe you are burning the oil-it doesn't get that hot and especially when you run them oil rich , slow and cool as I do.  I also had most of my engine collection (before I moved) in the same room with a large humidifier over the winter.  As I started packing engines to move and going through them one by one I found quite a few froze up and when I got some of them loosened and test run I discovered a good number ruined due to corrosion.  My suggestion in general is OFTEN oil up and flip through any engines you aren't using for a while to keep them in good shape.  I trashed maybe 12 -15 engines that beat me to the punch.
Offline kevin king
« Reply #12 on: May 05, 2024, 10:49:19 AM »
Kafin, are you using an electric starter on the engine?
Online Motorman
« Reply #13 on: May 05, 2024, 12:36:28 PM »
Black oil is usually from the con rod rubbing the back plate or bushings gone south. Make sure you have the steel washer behind the drive washer. Also, on some high mileage LA46 the sleeve plating can be worn through to the brass in places.
You'll be hard pressed to find a better 2 blade plastic prop than the TT 11x4.5.
MM 8)
Offline Steve Dwyer
« Reply #14 on: May 06, 2024, 05:55:31 AM »
I have noticed wear on the back plates of the Max-S engines. I always make sure the front bearing washer is in place. Has anyone ever tried adding additional backplate gaskets? There's an extensive amount of discussion on the Max-S engines here from back in the day, I'm curious, however, why this topic hasn't been covered more.  Why would a Thunder Tiger prop make any difference other than it has a thinner profile?
Offline Al Ferraro
« Reply #15 on: May 06, 2024, 07:44:35 AM »
  Looks like you are running the stock OS muffler which is very restrictive. I would run a 5/16 drill all the way through the exhaust to let engine breathe better or get a Dinger muffler. As far as props go, I would use the APC 11.5X4. I tried the TT 11x4.5 on my LA 46 powered Vector and on a calm day it works ok, but when the wind starts blowing the APC is the clear winner.
Al
« Reply #16 on: May 06, 2024, 09:31:06 AM »
The TT prop for the LA 46 was the magic prop. I never question magic. 🤣
Sort of like the old Rev Ups were the prop to swing. 👍🏼
Offline Steve Dwyer
« Reply #17 on: May 06, 2024, 06:19:57 PM »
Al
Al,
All the mufflers I have on my Max S engines are the strap around the head style with a approx. a 5/16" diameter outlet. Can you better describe where exactly you are recommending a 5/16 hole be drilled. I do believe I read somewhere here some mufflers had a much larger outlet and the engine ran better.
« Reply #18 on: May 06, 2024, 06:30:54 PM »
Al,
May be some confusion.  Al was talking about the LA .46 I believe.   We have always used the stock muffler on the FP and LA .40-.46 without issue.  Could be other factors involved .
Offline Steve Dwyer
« Reply #19 on: May 06, 2024, 06:33:38 PM »
OK thanks
Offline Jake Moon
« Reply #20 on: May 06, 2024, 10:32:07 PM »
Hi Kafin,
I run an LA-46 on a tongue muffler (all holes open) in my Vector 40 with 5% nitro, 20% oil mix and a 12.5 X 4 APC prop. I have tried a couple other fuels (5% nitro/18% oil, 10% nitro/18% oil, and 10% nitro/20% oil) and had either power issues or overheating. I've found that with the heat and extreme humidity in our climates that even seemingly small fuel changes can throw the motor run off.
Before takeoff I set the needle to where the motor is in 2 cycle and just cracking into a 4 cycle every couple seconds. The lap time is around 5.1-5.2.
Offline Perry Rose
« Reply #21 on: May 07, 2024, 05:57:29 AM »
Any time I've had a dark residue in the exhaust there has been something loose, muffler, engine hold down bolts. I mix my own fuel for the dozen .46's I run half and half oil and 2 % nitro from 1000' msl to sea level year round. APC 11.5 x 4 launch at 9000 rpm 60 to 63 foot lines. Stock venturi and whatever muffler will fit or needed for balance from stock or fox 35 or tongue.
Offline Al Ferraro
« Reply #22 on: May 07, 2024, 07:35:56 AM »
Al,
  The LA 46 muffler has a .270 exhaust pipe outlet hole. What i recommend is to drill out the muffler exhaust outlet pipe all through the pipe with a 5/16 drill to enlarge opening of the pipe to .320.
Al
Offline Colin McRae
« Reply #23 on: May 07, 2024, 07:43:04 AM »
I run muffler pressure on all of my LA's. And I typically re-check the muffler bolts for tightness every few flights.
If running muffler pressure, it is very important to ensure that there are no exhaust leaks (muffler not loose, fuel tank not leaking air, etc.). The needle will be set a bit more closed with pressure compared to no pressure for the same ground rpm. If the muffler becomes loose in the air, or a fuel tank air leak develops, pressure will be reduced or lost, and the engine will go lean.
« Reply #24 on: May 07, 2024, 10:15:23 PM »
EricV
Thanks Eric.
It turned out my muffler being loose.
After I tightened it up, the problem went away.
I really hope that’s the culprit, not the internal parts that are worn out
« Reply #25 on: May 07, 2024, 10:20:21 PM »
Thanks for mentioning this, Colin.
I was trapped to match the suggested ground RPM number for that specific prop on LA46 without finding what will work on my flying location.
« Reply #26 on: May 07, 2024, 10:24:59 PM »
There’s loose screws on the muffler. I was also thinking of putting a gasket in between the motor & muffler, good idea?
I will definitely have to go over to see if there’s any lose screws on the motor as well and try to fly it with 10% nitro fuel.
« Reply #27 on: May 07, 2024, 10:28:40 PM »
It’s a local brand fuel with 5% nitro 20% oil (which I suspect this is full synthetic oil).
I might have to try switching to VP Powermaster 10% Nitro 22 oil (50:50)
« Reply #28 on: May 07, 2024, 10:29:59 PM »
Kafin,
thanks,
Peter
Hi Peter,
It’s a secondhand engine I bought  from Bob Brooks.
Not sure how the engine is broken in fully or not.
« Reply #29 on: May 07, 2024, 10:42:55 PM »
Hi Kafin,
Hi Jake,
Thanks for sharing your thoughts.
Why did you decide to use 5% nitro fuel instead of using the 10%? I thought with the heat we have here it will be better to use 10% nitro.
I’ve been using 5% nitro for the past year but I was thinking to switch to 10% nitro.
« Reply #30 on: May 08, 2024, 12:22:43 AM »
That is what I ran mine on.  Good fuel.
« Reply #31 on: May 08, 2024, 06:50:43 AM »
No gasket should be required. I know the stock muffler comes with Phillips Screws. Don’t remember the size but if you can find hexhead cap screws to replace them they won’t come lose as often.
You should get in a habit of checking all screws and nuts from time to time. Just like real aircraft they require maintenance and inspections. You have a vibrating flying machine. Things vibrating lose is a bad thing. 😉
« Reply #32 on: June 09, 2024, 11:01:19 PM »
Hello
So far I have switched my prop from TT 11x4.5 to APC 11x4 and somehow it works better on my P40 with an LA 46.
I think I will keep this setup for a while.
However, one thing I noticed when I was flying yesterday was the plane had the tendency to go wiggly & down when I was flying level, not all the time though.
I believe the handle neutral was fine. Was that a CG problem? Or could that be caused by windy weather?
If it's a CG problem, where is the CG for P40 as shown on the plan?
My P40 balances well at around spar, at about 3" - 3 1/8" from the LE.
And it glides nice & level when the engine shuts off.
Best,
Kafin
« Reply #33 on: June 10, 2024, 02:36:03 AM »
Sounds like "black gunk" is no longer on your mind.  Great.
There's an excellent manual on trimming, but the first two aspects are pitch sensitivity and wings level.  CG forward, more stable.  CG back, tighter turns. So, yes, you are right that CG is a factor.
If you are getting wiggly bouncing, but only sometimes, I'd be concerned about wind, especially curling over trees or structures bordering the field, as well as your own wake turbulence if calm.
Have you read this dissertation?   Paul Walker on trimming:  http://flyinglines.org/pw.trimflow1.html
Peter
« Reply #34 on: June 10, 2024, 07:08:00 AM »
It is not a good idea to do initial trimming in wind.  So many factors are interrelated that it makes it difficult to determine which one is causing what, especially wings level.  If the plans state them, the CG and Tip Weight should be set to the plans and hope that the designer added them after he had the original trimmed.  Some are way off, especially older designs that used less powerful motors and electric conversions. Tip weight is very much plane dependent.  You have flown the P-40, so tip weight is most likely in the "safe" range already.  My "safe zone" for CG is the glide after the motor quits.  On a "classic" like design, the P-40 with the smaller tail, will not glide very far either nose or tail heavy for different reasons.  Peter's post covers that.   The "rule of thumb" is pitch up when motor quits = tail heavy, pitch down=tail heavy.  That is OK but if horizontal alignment on the plane is good it might not do either at first and still be tail or nose heavy.  You must allow it to glide on its own for a bit and observe what it does.
« Reply #35 on: June 10, 2024, 09:34:00 AM »
Hello
Best,
Kafin
      There is a big difference between wing and turbulence. If you are flying near trees, and the wind blows through those trees, it becomes a rolling, boiling mess of turbulence, and takes command of your airplane when flying through it. Even wing at a lower velocity can become a real pain and difficult to fly in. At the flying site I use often, I have seen both the bottom and top of my wing when flying level!! Nothing in flight trimming will improve on it. There are some smaller and more clean model designs that can handle it better. It's best to just not fly, or move as far away from the trees as possible. it takes a long time for the turbulence to lose it's energy and effect and smooth out. Straight line wind can be dealt with, turbulence is just a guessing game on how the airplane will come through it.
   As far as propellers, we have covered this many times before. Each airplane you have may require a different prop/engine combination. Airplanes have different amounts of drag, and also weight. The TT 11X4.5 is a good prop but your P-40 may just be a bit too big and too heavy for it to be really effective. The APC 11X4 has a much wider blade and will make more thrust for you and load the engine a bit differently. If you can get one, APC makes a 11.5X4 that will be worth a try. When trimming a new model you really need an assortment of props in a range that will work for that engine. You don't know what prop will work the best until you fly it and try it. It may take 2 or 3 flights to dial it in, but as the old saying goes, the proof is in the pudding!!
« Reply #36 on: June 10, 2024, 11:11:53 PM »
Well, I had flown that P40 multiple times before my last flying session (last Sunday) without any problem/any sign of wiggly bouncing on level flight.
As long as I can remember, the wind at those times were calmer than my last flying session when I had that problem, so I hope it was much more of wind/turbulence problem.
The windsock on my flying field last Sunday was staying straight most of the time, and I could feel the bounce when the wind was exactly behind/or in front of the plane.
« Reply #37 on: June 10, 2024, 11:14:54 PM »
This has been on my reading list for the last few week since my P40 maiden flight. Definitely a must read.
« Reply #38 on: June 10, 2024, 11:28:42 PM »
Yes, Dan. I also have APC 11.5x4 that I can try. But the ground clearance has prevented me to try that one.
I have actually changed my wheels to a bigger size, but I still won't have a 'safe' ground clearance if I put that 11.5x4 prop (considering I often have to deal with tall grass at my flying field).
So far, 11x4 has served me well to my current flying skill level. I might try that prop as I keep progressing to perform more demanding maneuvers.
Best,
Kafin
« Last Edit: June 11, 2024, 02:52:24 AM by Kafin Noe’man »
« Reply #39 on: June 29, 2024, 10:21:49 PM »
Hi Dan, I have finally tried flying with the APC 11.5x4, and the wiggle I had when I put TT 11x4.5 or APC 11x4 is gone now.
Is this due to the bigger prop diameter? Meanwhile, is it normal to suddenly have a faster lap time when going to a larger diameter prop size without changing anything else?
Best,
Kafin
« Reply #40 on: June 29, 2024, 10:48:33 PM »
   Yes.  It is more efficient, so more of the same shaft HP is transferred to the air, pulling the airplane faster.
     But, in fact, you changed way more than just the diameter, you also changed the blade shape and I bet if you check, the pitch is also different, as is the camber of the airfoil. That is why it is so difficult to know what different props might do in any particular situation, and why we pretty much switched to repitchable carbon or fiberglass props, you can adjust the pitch and pitch distribution on literally the same prop and have a chance of making sense of the results. There is still considerable cut and try required.
    A "wiggle" could mean anything, but certainly, putting on a heavier and larger diameter prop will absolutely change the trim state of the airplane. Usually it is a matter of larger props causing more trim issues and degraded turn capability. In this case, it may have altered the trim in a *favorable* way, since we don't know but might take a guess that you had significant trim issues before, too.
« Reply #41 on: July 03, 2024, 12:09:44 PM »
The TT 11 x 4.5 is a very good prop for a lot of engines, but too hard to replace when they break. The APC 11.5 x 4 is a great match for the .46LA. IMO, if you can't replace it and get plenty of spares, there's little point to even trying a prop.
I would suggest that 62' lines (eye to eye) might be better for the .46/P-40 combo, and if you are keeping track of your flight time/fuel load...and have surplus tank capacity...consider drilling out the outlet of the stock muffler. It will burn more fuel. Burning more fuel for the same run time will be a good thing.
Those Brodak ARFs had problems with the covering. I saw one lose ALL of the covering off one side of the bottom of the wing. It stayed in the air, but it's easy to see how it could result in a sudden crash.
I just don't like OS needle valve assy's, so count me as one who's not afraid to drill the case for a 4mm/.156" spraybar. I like Randy Smith's NV assy. and a .272" bore restrictor...not a true venturi. Pretty much the same spraybar and restrictor size for any 2 cycle engine works well. I've used that on OS .25LA > ST .G51 with good results.  H^^ Steve
Offline Al Ferraro
« Reply #42 on: July 03, 2024, 09:28:14 PM »
Best,
Kafin
     That doesn't surprise me at all, I had the same experience. Now drill out the muffler.
Al
« Reply #43 on: July 04, 2024, 01:33:12 AM »
Best,
Kafin
     Yes, that can happen, because you are making more thrust, so the model will speed up. A larger diameter prop can stabilize things a bit,  plus the little bit of extra weight can cause the the balance point to change a bit. What are your lap times now, and what were they before? If it bothers you, try opening the needle to slow the engine down about 200RPM and fly it a few flights. Be sure how you do or don't like the way the model feels now. If you want to try slowing it another 200 RPM, try it again. 200 RPM on these engines makes a difference some times, and I can't tell that by ear any more, so I use a tachometer. If things settle in  and you like it, keep flying it. Measure the line length from eyelet to eyelet and from handle to the center line of the airplane. If the model is still too fast, try a set of lines that are 2 feet longer. A lot of this you have to determine and feel it out. Fly several flights after each change to be sure of things and that you really want to change it, then change one thing at a time.. Comfort and confidence is the name of the game here!
