  • July 13, 2025, 12:38:48 PM
Author Topic: Silicone fuel tubing  (Read 1004 times)
Offline Richard Koehler
« on: February 20, 2014, 04:49:01 PM »
What brand of silicone tubing are people using, both for internal clunk tanks and connections tank to engine.  Here all I can get easily is the very heavy (DUBRO?) tubing meant I think for cars.  Right now I've got the last of my Sig tubing in my clunk tank.
Offline Allan Perret
  • Proverbs
Re: Silicone fuel tubing
« Reply #1 on: February 20, 2014, 05:43:23 PM »
Sullivan
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #2 on: February 20, 2014, 08:07:20 PM »
   Prather for the external tubing. Although the car stuff seems fine if you can ignore the fluorescent pink, etc. I don't use a lot of clunk tanks, and so far I have used whatever comes in the package with the Sullivan tanks. It has lasted many, many years so far.
« Reply #3 on: February 22, 2014, 02:06:55 PM »
A few years ago I bought a spool of Prather "Pink" tubing and use it on all my important stuff.  For the others, I often use color tubing which is easy to find. ;D
BIG Bear
« Reply #4 on: February 22, 2014, 11:12:26 PM »
So no one else buys 10ft at a time from McMaster-Carr?  I had some problems with the stuff from the local hobby shop and was ordering from McMaster-Carr anyway.  Been using it since 2011.  It's a bit stiffer than the hobby stuff, but it hasn't melted in my fuel jugs like the hobby stuff either.
5236K82 High-Temperature Silicone Rubber Tubing, Soft, 3/32" ID, 7/32" OD, Semi-Clear Blue, 10 ft. Length  $7.00
