  • June 24, 2025, 03:23:02 PM
Author Topic: Best modern profile for PA  (Read 15136 times)
Re: Best modern profile for PA
« Reply #50 on: August 23, 2014, 05:12:31 PM »
Hi Doc,
You can spring for a Anit-malware program called "Spyhunter" and that will stop all that nonsense.
Most of that crap comes in through Java or one of the similar programs.
I've been using Spyhunter for over a year and find it to be very good at stopping all that crap and periodically "cleaning" the entire computer.  I pay $59 a year for it and that allows three computers to use it.
Offline Gordan Delaney
« Reply #51 on: August 24, 2014, 10:13:55 PM »
   You can get the plans for the Twin Pathefinder from the guy that designed the plane with Gordon, and that is John Miller. He frequents the design and cad forums for the most part. Smart guy, good guy, great model builder. It was designed from the ground up as a stand alone model, but shares some components withe the Pathfinder, and I think he mentions in the article that you could start with a kit for certain parts. The wing is 700 square inches I think, much bigger that a standard Pathfinder.
Dan,
The twin Pathfinder was built off the Profile Pathfinder. It only has 640 Sq. inches. Not 700. I scratch built mine so I could keep the weight down. The stab was made from 3/8 instead of 1/2 Balsa. The elevator was narrowed 1/2 also. Both airplanes had the same wing though. My weight was 48 oz. John built his from a kit and his was 52 oz. Fp .15teens. Hope this info helps.
Gordy
Offline Jim Damerell
« Reply #52 on: August 25, 2014, 07:16:00 AM »
JD foam wings is again producing Prowler and Prowler Derivative Profile kits. The Prowler was an excellent flying airplane originally produced by Aerosmith, designed by Bob Hunt and Scott Smith. The kits I saw were excellent, with great wood and foam wings included. Contact John Duncan (JD foam wings in the vendor section) for price and availability.
Offline Horby
« Reply #53 on: August 30, 2014, 08:37:36 PM »
Where can one see what a prowler looks like?
Cheers,
Warren
« Reply #54 on: August 31, 2014, 08:21:53 AM »
Do a search.   I am too lazy to post all the other posts that have pictures and also a video is in the listing.
« Reply #55 on: August 31, 2014, 08:41:37 AM »
Cheers,
Warren
Here is my Prowler......
[/url]
In Flight
« Last Edit: September 01, 2014, 07:36:27 PM by Shug Emery »
« Reply #56 on: September 01, 2014, 07:06:17 PM »
Dan,
The twin Pathfinder is built from a Pathfinder profile. It has the same wing which is only 640Sq. inches. Same stab but 3/8 thick instead of 1/2 inch. and the elevator is a 1/2 less cord. Also a 1 inch shorter moment.
Hope this helps.
Gordy
