Vot Vee Doo , iss ;
Glass table outdoors , roof over it ( like a carport )
Threw four pieces of four by two ( these are two by four in America ), measured exactly positioning ( you could draw lines on the Flat Surface )
and a few scraps snapped from the same piece of particle board - the Idea is the mainspar sits on two - a tapered thickness wing youd pack
the 2x4s on their flats , half the tip / root thickness distance .
The T.E. 3x2
sits on edge , to give neutral height . Its not that difficult , if youve a bench saw , youd rip custom pieces , tapered edge for T.E. even
I sat the MC 72 out overnight with a extra packer equal & opposite the twist / warp - for a night or two . Then even so 4 or 5 nights .
I believe the Heat / humidity / coolness cycle helps , particularly to SET IT . Straight if its jigged straight .
If Youve used BUTRATE , you might find it retwists for up to TWO YEARS .
and miraculously one day is straight .
The FREE FLIGHT guys pin down their wigs while the dope ' gasses off ' for some reason ! .
I left a 1/16 sheeted wing on the lawn overnight , jury rigged on planks for the diheadral , and keepers at the TE as I Very Gently lowered
two Car Batteries onto packed 6x1s on top , and left it out for a few days .
This one Id stoopidly thrown balsa block L.G. keepers in under the sheeting and poured shrinking balsa cement thoroughly about them . It Stuck
BUT Id ended up with a ' Gull Wing ' MB3 .I then threw about 3 motorcycle batteries ( Just Kiddig - I dropped them gently ) , a few big files ,
Bits of steel , etc , to weight it . It Camme straight eventually , as Id done it a few times after when I was flying the sod .
OOPS , the MC72 Id used two matched 2x2 box section , two 2x2 angle iron , And two bricks on top , for the Two Wings .
Any BURRS or LUMPS in anything against the wing will leave impressions , so block sand if necessary the boards ,scrounged from the builders supply skip or a builders rubbish pile .
