It's a little thin of airfoil -- it'll probably never be more than a nice sport plane, although if it's light enough it may do the pattern.
If it didn't interfere with the tank, I'd put the bellcrank right below the cabane struts, at the vertical CG. I'd replace the left-side interplane strut with something that allowed for adjustable leadouts while still maintaining some strength, with the leadouts placed at the vertical CG and adjustable fore and aft.
Placing the bellcrank low in the plane won't change how it hangs from the lines (the leadout guide placement does that), but it will force a bend through the leadout guides, which will increase friction. I don't think it'll be significant, but others do -- there's been a lot of discussion about this, there to find if you look.
