  • July 14, 2025, 07:45:06 AM
Author Topic: My latest(Update, flight test)  (Read 2133 times)
Dwayne
« on: September 03, 2015, 01:39:43 PM »
I call this the  EZ-Stunt series as it uses a simple box fuse, non tapered Brodak Accentor wing, upright engine, the pushrod exits out the side of the fuse attaches to a nylon horn. I don't try to cover all the grain I apply 3 coats of dope, rattle can rustoleum, Ultrakote and trim sheets. LA 46 and weighs 44 oz. There's  no carving it looks good, it's light so it should fly well.
« Last Edit: September 06, 2015, 07:22:32 AM by Dwayne Donnelly »
Re: My latest
« Reply #1 on: September 03, 2015, 01:49:14 PM »
The plane looks great in the pictures.   Hope it flies as well as it looks also.   If you are just learning the ins and outs of the stunt pattern, that is the way to go.  Some of us spend to much time on finishing instead of building light and straight. H^^
Dwayne
Re: My latest
« Reply #2 on: September 03, 2015, 01:53:40 PM »
Thanks John. That is exactly what this is designed for, I'm just now getting the pattern down but am a long way from being good at it, this is my next step up from a profile, simple, straight, stiff, light and looks good.  y1
Re: My latest
« Reply #3 on: September 03, 2015, 03:03:01 PM »
Looks like a fun plane. Should be a blast to fly.
Re: My latest
« Reply #4 on: September 03, 2015, 03:28:54 PM »
LOL, I had the exact same idea! Tanager with a box fuselage/bubble canopy, I was going to call it the simplex and use electric power. Glad someone fleshed it out. The Tanager is a good flyer but the fuselage is flimsy, the Acentor has a log for a fuselage, this fixes all problems, should be great.
Re: My latest
« Reply #5 on: September 03, 2015, 05:06:21 PM »
That is a nice looking plane.  You had the right idea using a Brodak wing set.  I've used Brodak wing rib sets for several of my own design planes.  Saves a bunch of work!
Dwayne
Re: My latest(Update, flight test)
« Reply #6 on: September 06, 2015, 07:26:29 AM »
Thanks for the nice replies. It's been windy but I did get in a few flights, the LA 46 was flawless as always the plane flies very nice but even though it turns nice and tight both ways it requires much less handle input turn outside than inside, I'm hoping a simple handle adjustment will fix this, today doesn't look to bad fingers crossed.  y1
Offline Carl Cisneros
« Reply #7 on: September 06, 2015, 07:41:05 AM »
Dwayne
Me Likey   ~> ~> H^^ H^^ H^^
you gave me a great idea for my step up from a P-Force.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Dwayne
« Reply #8 on: September 06, 2015, 03:52:17 PM »
Dwayne
Carl
Thanks Carl, that was my intention with this plane, the basic idea can be used with any wing, measure the nose and tail of your P.F. and build a box fuse using the wing and tail from your P.F.  y1
Dwayne
« Reply #9 on: September 06, 2015, 04:00:02 PM »
Got in some good flying today, turned out all it needed was a little up elevator adjustment now it turns even both inside and outside. It flies straight and level upright and inverted like it's on rails, I'm very happy, just wish I'd built it years ago.  y1 #^ ~>
Online Allen Eshleman
« Reply #10 on: September 07, 2015, 09:52:58 AM »
Looks great!  I like planes with the engine upright.
What is your set-up on the LA-46?   What prop are you using?
Offline Richard Logston
« Reply #11 on: September 07, 2015, 11:28:57 AM »
Like they say KISS. (Keep it simple stupid) Love the functionality of the design. I also like the upright engine installation. Looks good, should give lot's of enjoyment in return. Richard
Dwayne
« Reply #12 on: September 07, 2015, 12:00:23 PM »
Hi Allen, it's a Zinger 11X5, I gave it a good sanding making sure the leading and trailing edges are rounded. One extra head gasket and a ST needle from RSM, DuBro 4oz plastic tank set up  uniflow, launch around 9800 and It runs like a Swiss watch.
« Reply #13 on: September 07, 2015, 01:38:21 PM »
Very nice Dwayne. I did that with a Banshee plan some years ago. I did make the wing thicker by adding top and bottom sheeting and cap strips. The fuse and tail feathers were my own design and it flew very well. You will notice the pushrod out the side of the fuse as per my R/C days. It has been flow with an OS 40 FP, an OS 35s, and a Fox 35. All worked well.
Dwayne
« Reply #14 on: September 07, 2015, 01:46:54 PM »
That's nice.  y1
