  • June 14, 2025, 04:02:46 PM
Author Topic: Fuel Percentages  (Read 1076 times)
Offline Casey
Fuel Percentages
« on: July 18, 2018, 12:47:13 AM »
For Bryon Fuels, can I take the oil percentages at it's printed values or do I give a discount and if so, how much of a discount do I give?
Re: Fuel Percentages
« Reply #1 on: July 18, 2018, 06:34:07 AM »
   I think there labels are accurate but you could call or email them for further information. Just add extra castor to get the 16% stuff up to what you want.  The other option is to do a boil down test and see what remains, but I think ithas been discussed on here before that their labels are accurate,  and at least they do tell you before you waste and engine.
« Reply #2 on: July 18, 2018, 08:00:36 AM »
I've used Byrons for quite a long time and believe the labels.  I buy the 20% oil, 50/50 mix and add oil-50/50mix, up to about 23% for modern engines and 29% for old classic engines.  Nitro will be 5, 10 or 15% depending on application.
« Reply #3 on: July 18, 2018, 01:25:32 PM »
Dave, looks like the old DOC is going to have to follow your lead so I can get some consistency on my runs. H^^
Offline richardhfcl
  • AMA 82448
« Reply #4 on: July 18, 2018, 01:42:51 PM »
Guys, I'm willing to believe the label.  However, I think that
we need to know whether or not the measurements are in %
by volume or % by weight.
     Thanks!
Richard Ferrell
AMA 82448
« Reply #5 on: July 18, 2018, 05:05:29 PM »
Doc it does make a difference.  I see sometimes folks trying to run the least amount of oil they think they can get away with-WHY?  OIL GOOD, HEAT- FRICTION BAD.  I've accidentally 'oiled' fuel twice.  Never noticed much difference other than a little heavier smoke trail.  The engines didn't complain.  Oil is cheaper than new engines.....If you are so close to the edge on the oil that you are concerned about weight or volume then you are simply too close to the edge.
Online RandySmith
« Reply #6 on: July 18, 2018, 07:47:40 PM »
I would  do a  boil down test,  I did this on Byron's  fuel years ago and found it very light on oil
Maybe they have changed it,  maybe not
