I also got a GHQ to actually run! But not before lapping flat the cylinder head, bypass, crankcase cover, and making new gaskets. I didn't have a tach at the time, but I estimate about 5000 RPM tops!
There has always been talk about that LH prop that came with GHQ. Since it is a sideport, and since the spark timer can rotate 360 deg. you can set the spark timing to run either CCW or CW. RPM is the same either way.
With a massive cast iron cylinder and cyl. head, it is a heavy beast. I have heard of some doing OK in boats.
