  • July 17, 2025, 03:39:28 AM
Author Topic: My Current Building Project : First Run Video!  (Read 5310 times)
« on: December 23, 2010, 07:53:50 PM »
Well, I was gonna do all sorts of stuff this winter, but I got right down to it and this is what I want to do right now. I've just begun the construction of a replica ACE 0.5 English Diesel (compression ignition for you purists out there). I'm using one of only several casting made by Roger Schroeder before he passed away. You can see I've just started the case machining and found a shrinkage void under the sprew, fortunately I think I got to sound material and I'll be able to finish it. Over the next few weeks I'll post more progress shots if you guys would like to see them.
« Last Edit: January 15, 2011, 06:49:57 PM by Randy Ryan »
Offline Russell Shaffer
Re: My Current Building Project
« Reply #1 on: December 23, 2010, 08:12:35 PM »
Fun!!!
Russell Shaffer
Klamath Falls, Oregon
« Reply #2 on: December 23, 2010, 08:18:11 PM »
I for one would like to watch your progress. You do very nice work, and us engine lovers want to watch.
« Reply #3 on: December 23, 2010, 08:21:58 PM »
You got it Jim!!!
« Reply #4 on: December 23, 2010, 08:38:37 PM »
Builder Of the Motor???
« Reply #5 on: December 23, 2010, 10:09:35 PM »
Builder of the Motor
Builder of the Model
Builder of the Motorcycle
An probably builder of some other M's that escape me at the moment.
Did your Dad ever show you the AHC diesel I built and gave him?
« Reply #6 on: December 23, 2010, 10:11:01 PM »
Step 8. Aw screw it, buy ARF.
Anybody can do that Ty, doesn't do anything for me. But hey, I know I'm a little weird.
Offline Bill Morell
« Reply #7 on: December 24, 2010, 12:22:59 PM »
Randy, I've been waiting for you to do something like this since you finished the Vivell. Always a pleasure to see the work of a craftsman.
Bill Morell
Vietnam 72-73
« Reply #8 on: December 24, 2010, 01:03:49 PM »
Hi Brother Randy!
Keep up the pictures as you go.  I will be following right along.
If I'm lucky (and have enough time left!) I would like to get set up for some machining work.  The "little" bit I have done kinda whet my appetite!
MERRY CHRISTMAS!
« Reply #9 on: December 24, 2010, 01:33:24 PM »
I'll be checking in on your progress, Randy. Wish they'd let me do Government Work where I'm employed, but they have a bad attitude about it. That sux!   :( Steve
« Reply #10 on: December 24, 2010, 01:49:13 PM »
Good to see.  I want to start doing that, but the most I've completed (that worked) has been a few venturis & needle assemblies, and little bits and bobs of model hardware (it's amazing how easy it is to spend half an hour making a hand-machined part to replace something that you'd by for $1.29 from Brodak's -- if you could wait for it to show up).
It's nice to see build logs from someone who can actually make it all work -- please keep posting pictures.
Reputedly, someone's picked up Roger's castings -- Hemingway?  If you could figure out who, and if they have any spares, and if you sweet-talked them enough, you may be able to get a replacement*.  I know Roger had a rep for replacing castings with defects, no questions asked.
* That's a lot of 'if's
« Reply #11 on: December 24, 2010, 02:33:52 PM »
My son is a machinest, and he says it's easy. You just take a chunk of metal, and cut away everything that isn't the part you are making. Yeah! Right! The good thing is, when I need a part made, or something machined, I just run it by him and it's done.
« Reply #12 on: December 24, 2010, 03:33:16 PM »
Tim, if you want to start out making something that will actually work and doesn't need to be super precise, build a steam engine.  You can run it on compressed air and save the complications and danger of a boiler.
Russell Shaffer
« Reply #13 on: December 24, 2010, 05:52:15 PM »
Actually, any long stroke/small bore engine is pretty forgiving to piston fit, because piston speed is very high. It's the short stroke/big bore engines that are the challenge, because the piston speed is relatively low...and the rpm is generally pretty high.  H^^ Steve
« Reply #14 on: December 24, 2010, 06:56:29 PM »
Thanks guys, I'll keep em coming!!!
« Reply #15 on: December 24, 2010, 06:57:53 PM »
Tim, Its a Brit that bought it, I nissed out by only a couple hours, I wanted to pick it up myself. I' get the namw (I should know it actually, but I don't)
« Reply #16 on: December 24, 2010, 07:39:25 PM »
It is Hemingway, at least according to my fave engine building site: http://www.modelenginenews.org/ed.2010.11.html#t3.  Hemingway mentions it on their web site: http://www.hemingwaykits.com/index.html, toward the bottom.
I've got a dead lawn mower that I've been saving in anticipation of using it's dead and broken crankcase for castings.  I think it's more likely that 40 years from now my progeny will haul it to the dump while asking themselves what in the heck was I thinking?
Re: My Current Building Project *** NEW PIX
« Reply #17 on: December 30, 2010, 08:20:31 AM »
OK, Got the pix down to a handlabel size so here goes, starting at the top:
First and sedond pix:
Case in the cradle block, this allows me to remove and replace the case for various operations without losing location. It'll have to go back in for the cylinder bolts
Third Pic:
Case chucked in lathe to cut the inside and cut the cover threads
Forth & Fifth:
The cover threaded end is cut and doubles as a chucking fixture to do the front finishing on the case.
Sixth-Eighth:
Cover is parted off and another stub is machined with the female thread the same as the case, the cover is placed inot it and the back is completed followed by a trip to the mill to cut the wrenching notches.
Nineth:
Cover on place in the case.
I have MORE to come.
« Reply #18 on: December 30, 2010, 10:08:05 AM »
WoW do you have a cool setup. You are the B.O.E. ;D
And when I first saw the blue parts I thought you were making a LA copy. LL~
Offline Bill Heher
  • Fix-it
« Reply #19 on: December 30, 2010, 12:33:40 PM »
Paul - it's Prussian Blue / layout dye. Used so you can make clear lines that come off easily( except from hands / clothes).
Also useful for things like lapping case backs and cylinder heads true and flat. Put on a thin coat - let dry and then swipe the part on your flat surface w/ 800 grit - low spots hold the dye, high spots it comes off and reveals the shiny metal. Gives you a good visual reference of the mating surfaces.
Bill Heher
If it's broke Fix-it
Offline rustler
« Reply #20 on: December 30, 2010, 01:27:18 PM »
How far do we take the BOM biz? I like Carl Sagen's analysis. If you want to bake an apple pie from scratch, you first have to create the universe.
Ian Russell.
« Reply #21 on: December 30, 2010, 07:17:44 PM »
Not a big fan of Carl Sagen so I can take it as far as I want!
Re: My Current Building Project *** Running Video
« Reply #22 on: January 15, 2011, 06:31:56 PM »
OK, well I obviously haven't been posting but I have been working on it. Here's a video of the first run. Old fuel made it hard to start, I'm going to try to mix sme fresh tomorrow.
Re: My Current Building Project : First Run Video!
« Reply #23 on: January 15, 2011, 08:03:42 PM »
It stops kinda sudden -- I assume it still needs breaking in?
You gonna build a little CL model for that?
Sigh -- I really need to work on the engine-building skills.
« Reply #24 on: January 15, 2011, 08:53:28 PM »
That was the first run, its tight and the fuel is old so its really sensitive to compression setting.
« Reply #25 on: January 16, 2011, 03:24:54 PM »
Tim....My experience with diesels (more than most, but plenty for me!) is that when the NV is leaned just a tad too much, it will quit very suddenly, with little audible warning, and no chance to richen the mixture and keep it running. I'd have made it a glow...or even spark ignition.
Randy, what's the displacement of that little feller? It's cute, anyway. You do very nice work!  H^^ Steve
« Reply #26 on: January 16, 2011, 04:20:44 PM »
Steve, its an .03 (.5CC) The fuel was very old with most of the ether gone, so it was very sensitiver to compression veriation. I mixed up some fresh today and it runs much more predictably.
Thanks for the compliment, since I don't do that work for a lkiving anymore, I enjoy it again!
« Reply #27 on: January 17, 2011, 09:35:49 AM »
That is great.  Diesels are a different breed of animal.  Just like four strokes they need to be tenderly fondled.  I love the diesels, but need to stock up on fuel ingredients before I get the Peacemaker flying.  Did I mention that is a cute little engine. H^^
« Reply #28 on: January 17, 2011, 10:52:26 AM »
Thanks Doc, funny, this little guy is physically about twice the size it needs to be as a .5CC engine, but very typical of early-mid 40's and even some late 40's designs. As a sideport its quite easy to handle, though this one still has me in the fog for the magic "combination" of mixture and compression setting it likes for cold starts. Most diesels will teach you what they want if you pay attention, not like glows that are much more tolerant of being flooded (actually too rich for easy starting).
